STD Other Projects W201 swap OM606 (french project ^^)
  • 1 Vote(s) - 5 Average
NEOS13
01-12-2012, 10:47 AM #1
hello
I'm new to forum I will present my side project (daily drive)
description and spec:
chassie is full stock
brake stock
OM606:
wastegate removed the manifold regulate the pressure at 18~20psi max
EGR remove
new timing chain
new water pump
power steering removed
A/C compressor removed ^^
stock turbo
2.5 IC
3 fan spal
OM602 flywheel (bi mass)
sachs OM602 clutch
OM603 IP:
4° after PMH
stock 5.5mm elements
valve ALDA removed (my IP is very learn litle black smoke)
full load adjust
torque capsul adjust
idle adjust
idle spring adjust (2K)
gauge:
autometer:
tachometer
pyro
boost
oil press
oil temp
water temp
fuel level
cyberdine:
speedometer
the car
is a W201 190TD OM602 engine and 5spd 717.437 gearbox
[Image: img0212l.th.jpg]
[Image: img0211iz.th.jpg]
im install sticker effect carbon
[Image: img0184nd.th.jpg]
the donor car:
[Image: img0177j.th.jpg]
[Image: img0203mo.th.jpg]
the OM606
timing replace (chain is used cams at 5° and pump 20°) bad idle and white smoke:
[Image: img0173zw.th.jpg]
[Image: img0199dt.th.jpg]
[Image: img0202mc.th.jpg]
after replace timing chain remove the engine in a W210 !!
[Image: img0205zk.th.jpg]
[Image: img0206pe.th.jpg]
[Image: img0207ag.th.jpg]
[Image: img0208r.th.jpg]
[Image: img0210fo.th.jpg]
cleaning the OM606 and manual 5spd gearbox:
[Image: img0214kj.th.jpg]
[Image: img0058wf.th.jpg]
install OM606 bolted at 5 spd gearbox in a W201 BOLT ON ^^
[Image: img0245uu.th.jpg]
[Image: img0244tj.th.jpg]
[Image: img0243uh.th.jpg]
[Image: img0242aq.th.jpg]
[Image: img0248ar.th.jpg]
[Image: img0246lm.th.jpg]
[Image: img0269ca.th.jpg]
convert harness for OM606
[Image: img0249nw.th.jpg]
[Image: img0250hd.th.jpg]
extra ^^ I install the locking and ignition key system W210 in a W201
transmeter and antenna
[Image: img0231mo.th.jpg]
[Image: img0227hw.th.jpg]
[Image: img0228gg.th.jpg]
isoled transmeter for no short circuit
[Image: img0230wyv.th.jpg]
compressor locking door conversion
[Image: img0232nt.th.jpg]
W201 key cuted for install in a rack W210 key
[Image: img0237dw.th.jpg]
[Image: img0236dr.th.jpg]
install IC and electric fan:
[Image: img0262wb.th.jpg]
[Image: img0263b.th.jpg]
[Image: img0343qt.th.jpg]
[Image: img0344gs.th.jpg]
adjust and install OM603 IP: is caled at 4° after PMH
[Image: img0356tj.th.jpg]
[Image: img0358r.th.jpg]
[Image: img0365fr.th.jpg]
homemade cluster gauge !!
[Image: img0367kq.th.jpg]
[Image: img0368gi.th.jpg]
[Image: img0369iv.th.jpg]
[Image: img0375jj.th.jpg]
[Image: img0922l.th.jpg]
[Image: img0928gw.th.jpg]
[Image: img0927l.th.jpg]
night
[Image: img0932fg.th.jpg]
car is finished !!
[Image: img0923ph.th.jpg]
[Image: img0926zu.th.jpg]
[Image: img0929h.th.jpg]
[Image: img0930qq.th.jpg]
sorry for my english ^^
This post was last modified: 01-12-2012, 11:50 AM by NEOS13.
NEOS13
hello
brake stock
OM606:
EGR remove
new timing chain
new water pump
stock turbo
2.5 IC
3 fan spal
sachs OM602 clutch
OM603 IP:
4° after PMH
full load adjust
idle adjust
gauge:
autometer:
tachometer
pyro
boost
oil press
oil temp
water temp
fuel level
cyberdine:
speedometer
the car
the donor car:
the OM606
night
car is finished !!
01-12-2012, 10:53 AM #2
that's a cool car
that's a cool car
