STD Maintenance General speedo wobble?
speedo wobble?
speedo wobble?
Purplecomputer
Slowness 220D
897
03-06-2012, 12:25 PM #1
What gives? This issue really annoys me. Makes me feel like i have a lemon
http://static.photobucket.com/player.swf...000438.mp4
This post was last modified: 03-06-2012, 12:27 PM by Purplecomputer.
Purplecomputer
03-06-2012, 01:31 PM #2
My speedo wobbles like crazy sometimes, I think its because whatever lubrication is in the cable wears out over time and then it binds for a second until it builds enough force to rotate again, then repeats the whole cycle really fast lol. That's just my guess though
Purplecomputer
Slowness 220D
897
03-06-2012, 01:33 PM #3
Never thought of it that way. So could i just spray lubricant down the cable? I always figured iy had something to do with maybe a spring or something inside thr actuale guage
Purplecomputer
03-06-2012, 01:36 PM #4
I was told these cables are sealed on the end, so I'm not sure if they can be lubricated very effectively or not, but its worth a try!! I think some really light oil or even graphite would work best
Purplecomputer
Slowness 220D
897
03-06-2012, 01:48 PM #5
(03-06-2012, 01:36 PM)sassparilla_kid I was told these cables are sealed on the end, so I'm not sure if they can be lubricated very effectively or not, but its worth a try!! I think some really light oil or even graphite would work best
So i should probably pick up a new cable?
Purplecomputer
03-06-2012, 04:20 PM #6
I still think it would be easier to just try lubricating it or something first
Hercules
03-06-2012, 04:37 PM #7
Lube the cable with very lite oil,10wt.or less.This usually only works if noise is the problem. Broken strands in cable causes jumping,(fix ),new cable.
Hercules
03-06-2012, 06:19 PM #8
^^^Either that or a graphite powder lube
Purplecomputer
Slowness 220D
897
03-07-2012, 10:03 AM #9
Thanks guys. Ill see if lubricating works.
Purplecomputer
