STD Tuning Engine oil cooler lines
oil cooler lines
oil cooler lines
oldtown
04-03-2012, 01:18 PM #1
any idea where i can get these with spending 250$ +
oldtown
serverman777
04-03-2012, 01:30 PM #2
http://www.google.com/products/catalog?q...CFoQ8wIwAA
'84 300 SD w126 Race Car Wink
'85 500 SEL w126 Scraped
serverman777
04-03-2012, 01:33 PM #3
partsgeek.com
partsgeek.com
oldtown
04-03-2012, 01:34 PM #4
(04-03-2012, 01:30 PM)serverman777 http://www.google.com/products/catalog?q...CFoQ8wIwAA
sweet thanks. obviously these dont look anything like stock. do you need some sort of adapters? can they handle the volume of oil?
(04-03-2012, 01:33 PM)willbhere4u partsgeek.com
i check PG, i was not sure about them not being OEM.
This post was last modified: 04-03-2012, 01:35 PM by oldtown.
oldtown
04-03-2012, 01:41 PM #5
Are the metal parts damaged or just the rubber? You can carefully dremel off the rubber lines and replace them with regular hydraulic hose from NAPA.
oldtown
04-03-2012, 02:22 PM #6
(04-03-2012, 01:41 PM)Simpler=Better Are the metal parts damaged or just the rubber? You can carefully dremel off the rubber lines and replace them with regular hydraulic hose from NAPA.
these are starting to leak where the rubber meets the metal. not sure i am confident retrofitting the hydraulic lines.
oldtown
04-03-2012, 02:41 PM #7
Take a look see here:
http://www.peachparts.com/shopforum/dies...ent-3.html
[Image: 1.jpg]
[Image: 2.jpg]
[Image: 3.jpg]
[Image: 4.jpg]
This post was last modified: 04-03-2012, 02:53 PM by Simpler=Better.
[Image: 1.jpg]
[Image: 2.jpg]
[Image: 3.jpg]
[Image: 4.jpg]
serverman777
04-03-2012, 07:32 PM #8
You and get nippes to screw into your oil filter house thing that you can pair up those lines with. I would get bigger lines than stock. bigger lines bigger flow
serverman777
