STD Tuning Engine om601 injection pump and ALDA
  • 2 Vote(s) - 3.5 Average
starykot
05-15-2012, 11:48 PM #1
Does anyone considered the possibility of mounting ALDA in the injection pump motor om601? A friend says that it can be done in a series injection pump. I, however, that the best solution would be to install the injection pump with a Mercedes Vito 2.3.
In general, whether it was a completed project om601 turbo in a forum? Somehow I can not find anything.
starykot
pp d
05-16-2012, 12:20 AM #2
It is possible to build the ALDA to it.
You can take off the ADA and put ALDA to it´s place.
pp d
starykot
05-16-2012, 11:03 AM #3
And what if the pump had no pre-ADA?
starykot
tomnik
05-17-2012, 05:39 AM #4
Hi,
change the entire governor.
Tom
(05-16-2012, 11:03 AM)starykot And what if the pump had no pre-ADA?
tomnik
Hi,
Tom
starykot
05-20-2012, 06:58 AM #5
Which injection pump / motor to look for Alda?
starykot
tomnik
05-20-2012, 10:31 AM #6
any M-pump for turbo.
Vito 2.3 Turbodiesel
124 all turbos
You could also use the n/a governor and get an external "ALDA" .
Tom
(05-20-2012, 06:58 AM)starykot Which injection pump / motor to look for Alda?
tomnik
124 all turbos
Tom
starykot
05-31-2012, 07:11 AM #7
I got the injection pump with the valve ADA.
Would not it be possible to rewrite the ADA at ALDA by appropriate calibration and plugging the hose from the intake manifold?
Does increasing the amount of fuel will be as big as the mount ALDA?
For now the project is supposed to be 100 hp, later Ream and eventually pump 150 hp with a spray of oil on the pistons.
What do you think?
Does anyone have any diagrams, drawings of how the ADA and ALDA?
The EPC and WIS is not too much.
starykot
What do you think?
pp d
05-31-2012, 08:46 AM #8
The ADA is no-good.
It goes all the way with 0,1 bar pressure.
pp d
The ADA is no-good.
starykot
06-03-2012, 11:04 AM #9
Is there a chance that, after assembly of ALDA will pump as much change as the dose of the factory turbo engines?
starykot
anjay
1998 E300 Turbodiesel
57
06-03-2012, 01:43 PM #10
What are you looking for as a goal of this modification? ALDA is reducing amount of fuel at low rpm
in order to reduce smoke emission. At high rpm gives a full fuel enrichment when turbo kicks in and is producing high boost.
This post was last modified: 06-03-2012, 01:45 PM by anjay.
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
1989 300TE - parts
starykot
06-05-2012, 12:10 PM #11
When you overclock the injection pump can be problems idling, uneven work, ALDA would solve this problem, if I'm wrong?
This post was last modified: 06-05-2012, 12:12 PM by starykot.
starykot
anjay
57
06-10-2012, 08:53 PM #12
I not think so! You have to get pump properly adjusted.
1989 300TE - parts
anjay
1989 300TE - parts
starykot
06-11-2012, 10:41 PM #13
So I overclocked ALDA and injection pump in a bunch om601 not?
I do not know whether the end to understand, I use the google translator, I do not know English well.
starykot
