STD Other FS / WTB / Buying guides WTB late style 617 turbo prechamber
Austincarnut
08-22-2012, 06:40 PM #1
I was wondering if any of you'd be interested in parting with a set of 617 prechambers, preferably the larger 14mm style. Please let me know, some how I ended up with 4 of each. To tell which ones you have, you need to look at the size of the opening where the injector nozzle will sit, where the heat shield/shim sits under the injector, there are 2 sizes on a 617, 8mm and 14mm. I need 1-2 14mm prechambers.
This post was last modified: 08-22-2012, 09:07 PM by Austincarnut.
Austincarnut
08-22-2012, 07:13 PM #2
I have a head which I am willing to canabalize so if anyone out there needs 3 let me know if I strike a bargain here.
Donor is the OM 617.952 engine. Turbo. How do you determine the 14mm style ? What does one measure.
Thanks,
Never mind .... I figured how to measure one. It is the size of a 9.5 mm socket. That is, in-between a 9mm and 10mm 1/4" drive socket. LOL Learned something new.
BTW -- why is the 14mm better than the 8 mm ?
This post was last modified: 08-22-2012, 07:31 PM by Greazzer.
Thanks,
Hercules
08-22-2012, 10:05 PM #3
Directs the heat away from the pintle.
Hercules
Hercules
08-27-2012, 05:06 PM #4
Forgot to say also the injector sets 1mm lower ,better atomization,better burn of fuel,(less smoking)
Hercules
Austincarnut
08-27-2012, 06:36 PM #5
What do you want for the 3? do you have pics? private email me!
(08-22-2012, 07:13 PM)Greazzer I have a head which I am willing to canabalize so if anyone out there needs 3 let me know if I strike a bargain here.
Thanks,
Austincarnut
Thanks,
