new guy, new car!
new guy, new car!
hey, new member who found this site here. Im not sure if im posting in the correct section so please bear with me, im new. I just bought a 1983 mercedes 300SD turbodiesel, and i want to make this think crank oout power! now i know these are serious tire burning machines. what are some simple things I can do to make this engine have more power off the line? and is it possible to convert it from an automatic trans to a manual trans?
Thanks,
Jon
(06-05-2009, 08:55 PM)Herrmanator8 hey, new member who found this site here. Im not sure if im posting in the correct section so please bear with me, im new. I just bought a 1983 mercedes 300SD turbodiesel, and i want to make this think crank oout power! now i know these are serious tire burning machines. what are some simple things I can do to make this engine have more power off the line? and is it possible to convert it from an automatic trans to a manual trans?also, what can i do to make my turbo loud like a cummins?
Thanks,
Jon
Thanks,
Jon
For starters make sure its in good running order. Simply having properly adjusted linkage, cleaned and turned ALDA can make your car seem new. Otherwise read.
i know alot about engines in general but im sorta new to some of the parts on my diesel so im not too quick on your slang like ALDA? whats that mean? are you talking about the throttle linkage?
thanks for replyin-- so i checked out those sites and found out a few things but I still cant find out what the linkage is or what the ALDA is. What is the linkage and how do i adjust it to run better? How do I clean and turn the ALDA?
Thanks,
Jon
okay thanks, i figured it out and have already cleaned the ALDA but the site has no specifications on turning the ALDA and still cant find any info on blocking the EGR.
Thanks,
Jon
(06-12-2009, 10:49 AM)Herrmanator8 okay thanks, i figured it out and have already cleaned the ALDA but the site has no specifications on turning the ALDA and still cant find any info on blocking the EGR.
Thanks,
Jon
Thanks,
Jon
