OM603 in C124 - prop?
Hi!
I recently bought a 300CE which I want to transform into a 300CDT with the OM603 turbo. I'm still on the hunt for a reasonably priced donor, during that time I want to gather as many info as I can.
What I don't know p.e. is, if the engine resp. transmission position of M103 and OM603 differ? In other words, if I take out the M103 & 722, will a OM603 with 722 bolt to the prop or is the prop too short or too long? Different flange dias not considered right now.
On the other hand I guess the engine could be moved forward/backward by modifying or DIY engine mounts?
Thanks!
Excellent! So a 'straight' swap and no different prop shaft needed Thanks!
