twin OM617's
twin OM617's
this is on a few other forums.. and I know its a bit off-topic here but as there are a few 617 fans on this forum
I thought I would share it here as well
the project before my SL300D was this:
<!-- m --><a class="postlink" href="http://www.coastalboatsales.com/jfraley/gallery/scubaboo?page=1">http://www.coastalboatsales.com/jfraley ... boo?page=1</a><!-- m -->
2x OM617's into a 28 foot sportfisherman
nothing superturbo yet.. but I have plans..
video of engines running on page 26
<!-- m --><a class="postlink" href="http://www.coastalboatsales.com/jfraley/gallery/scubaboo?page=26">http://www.coastalboatsales.com/jfraley ... oo?page=26</a><!-- m -->
That is a very cool project! I'd love to make an H-10 or I-10 setup in a pickup or something.
yeah.. just do it like they do in tractor pulling, tie two engines together
with a big chain
oel_brenner You have done what I have been dreaming of for a couple of years now. Awsome job!!! :mrgreen: Do you have a journal explaining the build pictures? I noticed that you had to replace an engine part way through.
With your planeing issue, these props were the ones used with the 454's? Is it a lack of RPM or HP/Tourque?
Thanks..
I dont really have a journal, just the captions along with the photos.
I did have to replace one engine, broke a timing chain
they are not the original props, I am running much larger/flatter wheels
then the 454's used because of reduced engine RPM and I am running a reduction gear
look around online for a prop calculator that will get you close, then trial and error
these guys have a good prop calc:
<!-- m --><a class="postlink" href="http://boatdiesel.com/">http://boatdiesel.com/</a><!-- m -->
and if you want to do more math and less trial and error get Dave Gerr's book:
<!-- m --><a class="postlink" href="http://www.amazon.com/Propeller-Handbook-Installing-Understanding-Propellers/dp/0071381767/ref=sr_1_14?ie=UTF8&s=books&qid=1223834261&sr=8-14">http://www.amazon.com/Propeller-Handboo ... 61&sr=8-14</a><!-- m -->
it is the absolute reference to the science behind marine props
There is a guy in out in New Orleans who built a downeaster from scratch
and powered it with a single OM617 and has had pretty good success
some videos of my boat running for all you OM617 heads out there..
http://www.youtube.com/watch?v=n4XzRJ0hTGs
http://www.youtube.com/watch?v=UqbRMGi72CM
sweet that looks like fun!
Ole Brenner, I contacted you a while back about your adapter plate on another forum. I now have a 1975 23' Penn Yan Tunnel drive with reverse rotation. (Right hand). Did you get a reversing trans for one of your engines & what ratio & make? As I can only fit a 12-13" prop in the tunnel, the prop will have to be super custom if I go for a 1:5 ratio. All of the PY's have the 1:1 VD trans. Any details will be greatly appreciated, as I am going back to work at the boat yard (Melbourne, FL) & will have access to the Lathe, overhead, plasma, TIG & MIG. Were you ever able to find the measurements on the plate? Also, are you just running both LH rotation? Glad to see you on this board, as it's somewhat kinder than the others. Ed
(08-08-2010, 04:42 PM)yankneck696 Ole Brenner, I contacted you a while back about your adapter plate on another forum. I now have a 1975 23' Penn Yan Tunnel drive with reverse rotation. (Right hand). Did you get a reversing trans for one of your engines & what ratio & make? As I can only fit a 12-13" prop in the tunnel, the prop will have to be super custom if I go for a 1:5 ratio. All of the PY's have the 1:1 VD trans. Any details will be greatly appreciated, as I am going back to work at the boat yard (Melbourne, FL) & will have access to the Lathe, overhead, plasma, TIG & MIG. Were you ever able to find the measurements on the plate? Also, are you just running both LH rotation? Glad to see you on this board, as it's somewhat kinder than the others. Ed
Yeah, that ZF gear is a bit pricey, but with going back to work at the boatyard, I may stumble across something. I thought about just running in reverse with the VD, but there's a reliability issue there. Thalks, Ole...
