STD Tuning Engine Pump energy consumption
dalek
07-05-2009, 08:57 AM #1
How much HP/W does a Bosch MW pump needs to work at idle and, say, 5200rpm?
I am not here to make waves; Sois jeune et tais toi
dalek
07-05-2009, 09:16 AM #2
Test benches use a 10-20hp 220v motor to run the pump during calibration. Remember, the pump spins at 1/2 engine speed.
Motorhead
07-05-2009, 10:00 AM #3
(07-05-2009, 09:16 AM)ForcedInduction Test benches use a 10-20hp 220v motor to run the pump during calibration. Remember, the pump spins at 1/2 engine speed.
Does the amount of energy needed to spin the pump go up as the fuel volume goes up, I would like to see what the pump requires for energy at 4,500 engine RPM with no load v/s load.
I would think the bigger elements would be a source of load increase, maybe even higher pop off pressure could add load.
Motorhead
