STD Tuning Engine OM606 NA and OM606 turbo injectors – are they the same?
maxypriest
09-05-2013, 05:22 AM #1
I’m still using my OM606 turbo engine in my w210 daily driver (has turned out to be a cracking car). However I have a NA engine in the garage – can I send those injectors off to be re-freshed and pop them in the STD project later?
PS only just found out that OM stands for 'oil motor'...
maxypriest
Druk
09-05-2013, 03:25 PM #2
I've got both engines logged in my EPC. The N/A injector part number ends 05 51 and the turbo injector 06 51
There must be some difference but quite what I can't tell from the EPC. DieselMeken might know if you send him a PM.
Druk
dieselmeken
09-06-2013, 12:58 AM #3
Nozzle is the same, DN0SD310 in both TD & N/A Engines. Difference is in the opening pressure, N/A 115 bar, TD 135bar
DN0SD310 is stock in some of the following Engines
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
Superpump equipped OM60X I set the pop pressure to 150bar
dieselmeken
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
maxypriest
09-07-2013, 05:19 PM #4
(09-06-2013, 12:58 AM)dieselmeken Nozzle is the same, DN0SD310 in both TD & N/A Engines. Difference is in the opening pressure, N/A 115 bar, TD 135bar
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
Goran, So it will be fine for me to send you some NA injectors to be modified to 150 bar for a superturbodiesel engine?
Cheers,
Max
maxypriest
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
Cheers,
Max
EDH_Performance
09-07-2013, 07:05 PM #5
(09-07-2013, 05:19 PM)maxypriest
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
Cheers,
Max
Yes, it is the same injectors! 150 bar is a good pressureBig Grin
EDH_Performance
OM605.912 83KW
OM605.962 110KW
OM606.912 100KW
OM606.962 130KW
Cheers,
Max
