help for OM605 swap to w201
Hello everyone im new in this forum , I have questions anyone can help me
I want to know what I need to put om605 (without adjustments) original om605 , 5-cylinder (150 h.p) swap to W201
I can start with original om605 fuel pump or i need to change to mechanic pump with OM602
Another important thing what i need to know .
Thanks!
Greetings to all !
(11-24-2013, 06:47 PM)ad0 Hello everyone im new in this forum , I have questions anyone can help me
Thanks!
Greetings to all !
Thanks!
Greetings to all !
very easier the second option ?? than first option..
original elements of the fuel pump om605 - 5.5 mm or 6.0 mm?
if I want to put a mechanical pump ( om602) what elements need to put 7.0 mm or 7.5 mm or 6.0 mm ....?
dynamics of engine will change ? will give the same results or will be a little faster?
because I will use it for daily driving
roughly to do 160-180h.p first stage
(11-28-2013, 05:39 AM)ad0
as mentioned earlier....you have to decide...will you go mech or electrical
mechanical is easier less initial work and more room for pimping fuel supply
as for second option ... just buy whole donor car... as to my knowledge
c250td are quite cheap in Bulgaria and just swap EVERYTHING to w201
if you dont have any automotive electric knowledge just take snapshot
of EVERYTHING before disconcerting plugs
if 380hp is your final goal..well... save some money..contact dieselmaken
and off ya go ....
My advice, forget the electric pump, you will probably never get it running. Use your 602 pump as it is. Install the pump on the engine, install the engine and gearbox and make it a running car. When everything works fine and you still feel like working, then you can think about more power(bigger elements, bigger turbo, intercooler, etc) I have seen so many projects where the owner wants to do everything at once and never finish and sells the car in parts with a big loss. So do it step by step and make it running between every step
