STD Tuning Engine OM 617 Water Pump Pulley Size
zeeman
01-11-2014, 09:06 PM #1
I have two core engines I am rebuilding, one has a smaller dual groove pulley on the water pump. The other is missing the pulley. In looking at my engine for my 300SD it has a larger dual groove pulley on the water pump. Are there two different dual groove sizes?
zeeman
capflya
Dreaming of a VNT
309
01-12-2014, 12:42 AM #2
Two different pulleys yes... If I remember right the '85 cars got a different sized pulley that spins the water pump faster so it is smaller. They also got the fan blade with more blades (9 or 11 I forget the count).
capflya
Austincarnut
01-12-2014, 08:56 AM #3
the earlier na engines on the G had a smaller pulley also
(01-11-2014, 09:06 PM)zeeman I have two core engines I am rebuilding, one has a smaller dual groove pulley on the water pump. The other is missing the pulley. In looking at my engine for my 300SD it has a larger dual groove pulley on the water pump. Are there two different dual groove sizes?
Austincarnut
