STD Tuning Engine compression ratio??
compression ratio??
compression ratio??
pmj4147
T04R + TD06
42
02-17-2014, 10:08 AM #1
Does anyone know 2.9ltr 602LA stock compression ratio??
I'm thinking about lowering the CR...
For more boost!!!!!!!!!!!!
I used 2bar normal, 2.3bar peak but didn't holded much
Head gasket blowedSad
This post was last modified: 02-17-2014, 10:08 AM by pmj4147.
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
F.R.A.S
02-17-2014, 10:26 AM #2
Headgasket failure is not due to compression ratio. Try o-ringing the block or block and head or use another type of gasket.
F.R.A.S
Eric78
02-17-2014, 11:58 PM #3
Is it 22:1? all the Merc OM60# engines are 22:1, although I've heard that Ssangyong uses 18:1.
Eric78
hansendk
02-18-2014, 04:44 AM #4
according to the SsangYong manual OM662LA is 22:1
lowering the ratio is normally used on marine engines to get higher HP
your US guys just look at Chevy 6,5 TD they use marine pistons to lower the ratio,
as long as you accept less low rpm performance and that it uses more fuel it can be done
hansendk
pmj4147
T04R + TD06
42
02-19-2014, 04:02 AM #5
i found the info of it....
all of 60* engines are 22:1, Mine too.......................
But.....What's the lower limit of CR???
I thought 18:1 would be great
But dunno exactly.
pmj4147
But dunno exactly.
