STD Tuning Engine 1991 300d almost stalls please help
300dw124
02-28-2014, 02:57 PM #1
Im new here I just purchased a 1991 mercedes 300d 2.5 my issue is when I let off the fuel pedal the car it almost stalls sometimes it will shut off too. Can anyone help me anyone else ever have this issue?Huh
300dw124
Stevo-trendy
02-28-2014, 03:58 PM #2
Air leak ? Check your fuel pipes the clear ones go hard & brittle with age & split letting air into the system , also worth taking the fuel tank strainer out & cleaning it if it hasn't already been done
Stevo-trendy
300dw124
02-28-2014, 04:15 PM #3
Thnak you I will take a look and see if thats the cause
300dw124
Duncansport
02-28-2014, 07:30 PM #4
Does it always idle low? Id start by checking the overvoltage relay and it's fuse mounted on top. It is located behind the battery, red with a 10A fuse in the top.
Duncansport
300dw124
02-28-2014, 11:58 PM #5
It idles just above the 5
http://youtu.be/6Am-od9sncU this is a video of what its doing
This post was last modified: 03-01-2014, 12:06 AM by 300dw124.
300dw124
Duncansport
03-01-2014, 07:07 AM #6
Idles to low, check the overvoltage relay. If it's ok check the elr for power.
Duncansport
300dw124
03-01-2014, 11:49 AM #7
Where are they located
300dw124
Duncansport
03-01-2014, 03:04 PM #8
(03-01-2014, 11:49 AM)300dw124 Where are they located
behind the battery clipped to the ABS controller bracket
Duncansport
300dw124
03-02-2014, 02:28 PM #9
I checked everything the lines are good the overvoltage relay is good still havnt found the elr. Im starting to loose hope
300dw124
Duncansport
03-02-2014, 05:41 PM #10
Elr is the red hoocky puck looking thing sticking off the back of the injection pump. It has a two wire plug on the top that controls the idle
Duncansport
Tito
03-02-2014, 09:10 PM #11
Could be me but isn't that thing overheated? I never ever got mine above 80.
Tito
300dw124
03-02-2014, 10:38 PM #12
I hope its not over heating I dont know the normal operating time
300dw124
Duncansport
03-03-2014, 08:14 AM #13
(03-02-2014, 10:38 PM)300dw124 I hope its not over heating I dont know the normal operating time
Did you check the ELR yet Huh Operating temp is between 80-100C on the gauge.
With the engine running there should be a ground and some sort of power at the connector for the elr.
Duncansport
300dw124
03-03-2014, 01:54 PM #14
Thank you duncansport the idle was the problem now its ruining alot better
300dw124
Duncansport
03-03-2014, 04:23 PM #15
(03-03-2014, 01:54 PM)300dw124 Thank you duncansport the idle was the problem now its ruining alot better
glad to hear! now time for some pump work, turbo, exhaust manifold and intake manifold! Big Grin
Duncansport
300dw124
03-04-2014, 12:17 AM #16
What kinda stuff can I do too the intake manifold and exhaust manifold to upgrade then and what turbo can I use?
300dw124
Duncansport
03-04-2014, 09:06 AM #17
(03-04-2014, 12:17 AM)300dw124 What kinda stuff can I do too the intake manifold and exhaust manifold to upgrade then and what turbo can I use?
PM, i have a bunch of modified OM602 parts (intake with external inlet, exhaust manifold with external waste gate and a T3 flange)
Duncansport
300dw124
03-04-2014, 04:47 PM #18
Pm sent
300dw124
Pm sent
