STD Other FS / WTB / Buying guides WTB: OM60# series Pump timing basket.
Eric78
03-11-2014, 12:08 AM #1
I'm looking for the Diesel injection pump timing gear locking basket for the OM60# series engines.
Part: 601-589-05-14-00
Or some substitute for this tool.
Eric78
Druk
03-11-2014, 03:06 AM #2
There's drawings to make your own here. http://www.superturbodiesel.com/std/Thre...pump-tools
Whether it's absolutely necessary or not seems open to debate. However....Huh
This post was last modified: 03-11-2014, 03:08 AM by Druk.
Druk
Eric78
03-11-2014, 03:28 AM #3
(03-11-2014, 03:06 AM)Druk There's drawings to make your own here. http://www.superturbodiesel.com/std/Thre...pump-tools
Shouldn't whatever method of locking the timing gear on an 0m617 work anyway? Or for that matter shouldn't it be similar to locking a cam sprocket when you remove a head?
Eric78
03-11-2014, 12:06 PM #4
In case you don't know, early engines came with these installed. I picked one up in a junkyard a while back very cheap. I could probably get the job done without this tool especially if I had a helper and maybe a wire coat hanger.
