STD Tuning Engine M and MW pump Delivery Valve difference
cho
03-31-2014, 03:39 AM #1
hi guys
before I dismantle one of my M pumps Smile can someone share some info
about M and MW pump delivery valve / druckventil compatibility.
for the pes5MW55 pump DV pn is 1 418 512 008,so...can those be used
in pes5M55 pump and vice versa?
thanks
edit: according the mercedes codes it is same - 0000747584 ; 0000741115; 0000742215
This post was last modified: 03-31-2014, 03:48 AM by cho.
cho
hi guys
thanks
dieselmeken
03-31-2014, 09:29 AM #2
(03-31-2014, 03:39 AM)cho hi guys
thanks
No you cant use MW deliveryvalves in M-serie. Dont fit. M-serie can be used in MW but they have not the correct outside diameter so you need some kind oring that puts the valve in centre of the element.
dieselmeken
thanks
cho
03-31-2014, 12:32 PM #3
thanks G. Smile
cho
thanks G. Smile
cho
04-03-2014, 02:00 AM #4
while we are on DV topic,..last time when I changed my DV's on MW pump
after taking DV holder off fuel was squirting like 15 minutes.. 0.5L went out... I watched Goran's video on dv change (om602 I think...) and there was no fuel at all....is this normal or I hit some weird tdc angle...?
Dodgy
cho
Dodgy
Tito
04-03-2014, 01:26 PM #5
I was messing around with my pump last week and when I took of the pre pump, fuel kept dripping from the fuel lines. I think this is from the fuel tank as the heat expands it a little bit. I don't know if there's a little hole for the air to enter the tank. If so than it's probably because my tank sits behind the back seat and was nearly filled. And the pump sits lower than the fuel level.
Tito
cho
04-04-2014, 01:56 PM #6
hmmmm...yes...maybe next time I have to pinch fuel supply line to prevent
fuel squirting.....
cho
fuel squirting.....
