STD Tuning Engine Quick OM603 Question
silverzx
11-13-2014, 08:24 AM #1
Do these come with an inline manually adjustable pump as standard?
Found something fairly local and am interested to find out a bit more about the "standard" engine before making an offer.
Would like to think a HX35 could be bodged on and "max fuel" adjusted?
Edit: It's a W124 92 300TD if that helps.
This post was last modified: 11-13-2014, 08:28 AM by silverzx.
silverzx
F.R.A.S
11-13-2014, 10:53 AM #2
Yes it's a mechanical IP on those. Max fuel will give you about 150hp. Cheers.
F.R.A.S
silverzx
11-14-2014, 03:38 AM #3
(11-13-2014, 10:53 AM)F.R.A.S Yes it's a mechanical IP on those. Max fuel will give you about 150hp. Cheers.
That's it? 150? Even with the likes of a large free flowing exhaust, big turbo, FMIC etc?
The pumps the limitation then I suppose?
So a pump from an OM617 would be needed almost right away, and they have 5.5 elements as standard?
I was under the impression the OM603 pump was VAC operated?
silverzx
F.R.A.S
11-14-2014, 04:36 AM #4
The om603 IP is 5.5mm and you can't use a om617 IP. What you can do is fit larger elements in the IP to 7.5mm or 8mm. Yes the IP is the bottle neck here. A petrol car will give more power on boost even though the fuel is running low. The diesel will not and will not even boost more then you have fuel for.
You could buy an electric IP from a om606-turbo and switch the elements so you get 6mm in your om603 IP. Not the best ever if not having a diesel test bench but it will work. Then you read the "set max fueling" thread here and you might have enough fuel for 200hp.
F.R.A.S
EDH_Performance
11-14-2014, 08:01 AM #5
Correct as FRAS says, the 5.5mm elements will not give out much fuel...Sad
The fun begins when they are 7.5 or 8mmSmile
EDH_Performance
