STD Tuning Engine Oil Temp and Pressure sender location?
Booster
04-01-2015, 02:24 PM #1
Where does everyone put there Oil temp and pressure senders??
This is on a om605.
What thread is used also? 1/8th not??
Thanks!
Booster
This is on a om605.
Thanks!
04-01-2015, 03:15 PM #2
got mine bolted in the filter housing in a flat surface. pressure sender is the original MB.
Booster
04-01-2015, 03:21 PM #3
(04-01-2015, 03:15 PM)barrote got mine bolted in the filter housing in a flat surface. pressure sender is the original MB.
I can't see where you mean? original fitment? I don't suppose you have a picture?
Thanks
Booster
Thanks
04-02-2015, 05:47 AM #4
yep i dont,
remome the filter housing, they usually are interchangeable, drill a hole in a flat surface in such a way that it does not disturb the filter element. cut a thread and bolt on the temp sender. usually they look like a bolt. sender for pressure transmiter u can have from the original plug, even if your car filter housing does not have the plug there, u have the hole tapped there. actually usually there is 2 of them , but one is not suitable for press take.
yep i dont,
