STD Tuning Engine Cam regrinding on OM606 need help about lash?c
TurboTim
04-28-2015, 09:07 PM #1
Crower is regrinding my cams right now and we are looking at getting 30 degrees more duration but does anyone know how much lash the lifters can make up or has anyone had to shim under the buckets?
76 300TD custom lots of stuff
TurboTim
04-29-2015, 09:33 AM #2
Sorry I'm of zero help here, but how much of the base circle is getting ground off? Just curious.
Cat cams sells .5mm valve stem caps.
TurboTim
04-29-2015, 11:10 AM #3
I think they were going to do .030
TurboTim
F.R.A.S
05-01-2015, 03:04 AM #4
Look at the facebook site in my signature.
F.R.A.S
TurboTim
05-01-2015, 06:53 AM #5
How long you used them? What about the weight?
TurboTim
TurboTim
05-01-2015, 06:54 AM #6
How thick are they?
TurboTim
How thick are they?
TurboTim
05-01-2015, 08:36 AM #7
and last question.....How much?
TurboTim
F.R.A.S
05-01-2015, 04:22 PM #8
Thickness is depending on how thick you need them Big Grin
Send me a PM about the rest Smile
F.R.A.S
mytmousemalibu
05-04-2015, 05:49 PM #9
Glad Crower is able to help you out! I'm anxious to see your results when finished, I may have to do the same. And lash caps were what I was thinking to compensate whats been taken off base circle also.
_______________________________________________________________
87' 300D daily driver, under the knife for a OM606 superturbo build!
82' 300SD~ Parting Out
93' 300TE~ Parting Out
89' 300E  ~ Parting Out
83' 240D~ Project "Cheap Drive"
03' 2500HD Dmax, lots of goodies
88' RX7 10th AE, 13B rotary Track Car Project
73' Datsun 510 wagon~ future project
79' Camaro Z28~ future project
mytmousemalibu
whipplem104
05-07-2015, 01:55 PM #10
It occurred to me that you could have the cam plate milled down to make up for the smaller base circles. You would have to make sure the timing chain tensioner could pull up the slack in the timing chain or remove a link and also either adjust the timing gear for the cam timing or adjust the profile on the cams to get it back where you want. It might not be enough to make a lot of difference but it would retard the timing. You would have to degree the cams to find out.
whipplem104
05-11-2015, 10:42 AM #11
hello there,
how much lift are u doing with this regrind? if is just a 1mm the hyd tappets shoud cover for it and the timing staying the same? right?
hello there,
