STD Tuning Engine How big should be the exhaust?
DaimlerDK
08-20-2015, 05:50 AM #1
Hello,
how bis should be the exhaust, on an OM606 with TB70 and 7.5mm Pump?
I dont come over 1.2bar pessure with my orig. exhaust, is this a Problem?
King Regards
Kay
DaimlerDK
Hello,
King Regards
Kay
m1tch
08-20-2015, 06:36 AM #2
I have found that the stock system on my E300 with the OM606 is actually quite good at 2.5" - the car was the fastest production diesel car when it came out after all, I will be looking for a 3" exhaust, although for me I have an issue with the fact that the steering rack gets in the way of having a large downpipe + exhaust, a 3" system seems to be the norm though.
m1tch
08-20-2015, 07:54 AM #3
70 to 80mm all the way to the rear, with a small mufler at the end , mufler not silencer Wink
08-20-2015, 07:56 AM #4
I am keeping the stock 2.5" exhaust with de-silencer & de-cat. The turbo is a rotary muffler anyway.
m1tch
08-20-2015, 08:58 AM #5
(08-20-2015, 07:56 AM)Hario I am keeping the stock 2.5" exhaust with de-silencer & de-cat. The turbo is a rotary muffler anyway.
I will be looking to add an 'exhaust cutout valve' to mine Big Grin
m1tch
AlanMcR
mind - blown
400
08-20-2015, 11:34 PM #6
I upgraded my OM606 based G with a shorter exhaust path (right side only). 2.5" tubing all the way out, with nothing but a Magnaflow 12276 in the path. That is a 24" stainless steel packed straight through silencer. Not at all noisy and the G went from 15.5s to 13.5s with no other changes (factory ECU).
AlanMcR
