STD Tuning Body Mods Has anyone "shaved" their W123?
08-25-2015, 12:31 PM #1
Looking at getting rid of the molding altogether.
I look at new cars and they have no molding.  I look at custom cars and older high-end cars and they have no molding.
Does anyone have any pictures of a W123 without molding?
Also, looked at recessed / shaved door handles.  Not sure on that one yet.  Any snappies out there on this one too?
EmJay
08-25-2015, 01:08 PM #2
If you decide to get rid of the moulding, I could use some of the clips for the driver door
EmJay
08-25-2015, 01:54 PM #3
Those red buttons? I have a bunch of them, enough for one piece of molding if you want them if I go that route. They are only .10 a pop or so new.
08-25-2015, 02:19 PM #4
The official term is *red monkey assholes*.
Someone on STD or PP was running a w123 with no cladding, I think jenryus? The guy with the hillbilly w/ bugeyes as his avatar.
EmJay
08-25-2015, 02:27 PM #5
I have the red ones, I need the black ones to shove into the red ones.
EmJay
08-25-2015, 08:09 PM #6
(08-25-2015, 02:19 PM)Simpler=Better The official term is *red monkey assholes*.
I think I know who you mean, but the spelling of the name is off a hair.  I will stumble into him.  Thanks Ryan.
08-26-2015, 08:53 PM #7
I've seen one as well, but can't remember who did away with it...
I kinda like mine because it keeps my doors from all dinged up.
EmJay
08-27-2015, 08:20 AM #8
Thought I saw a 85 350SDL that didn't have any at PullAPart
EmJay
bt1211
10-24-2015, 07:26 PM #9
here is a CD pic that I took off the web. Mi[img]file:///C:/Documents%20and%20Settings/Brian/My%20Documents/My%20Pictures/Coupe.JPG[/img]ne is also shaved but it aint ready to post[img]file:///C:/Documents%20and%20Settings/Brian/My%20Documents/My%20Pictures/Coupe.JPG[/img]
bt1211
10-24-2015, 07:47 PM #10
Thanks ! I like it ... Wonder if that blasted drip edge / "A" pillar molding could be shaved off too?
bt1211
10-24-2015, 07:52 PM #11
yea, it could but that would be quite the gap to weld and lead. I did it on my 911 a few years back and to this day I still worry when its going to crack
The 4 door looks very Rolls Royce-ish in the last pic
This post was last modified: 10-24-2015, 07:54 PM by bt1211.
bt1211
10-25-2015, 08:16 AM #12
Thanks again ! I like the shaved look ... even getting rid of the very bottom molding looks good.
BTW, when you welded over the "A" pillar - gutter molding/drip edge, was it simply just one weld, or was it more involved? It's been around 4 years since I had to remove and replace that molding and I only recall a pinch weld at the top - roof line.
bt1211
10-25-2015, 12:09 PM #13
It took a long time cause I did a little at a time, so I wouldn't warp it. At the time my skills were not that good but it was something I could manage if I did a section at a time
It was the first time I leaded but it was pretty easy. Lots of how to videos on the web
bt1211
bricktron
'77 240D
174
02-18-2016, 01:51 AM #14
[Image: 1484905d1434317600-w123-official-photo-g...-trim4.jpg]
(^^ not my car)
i have gone a ways down this road too. pretty content by this point running with no body trim at all but i haven't filled the holes. even the A/C pillar trim is gone and i don't miss it. a couple of funky body features are revealed this way but what are you gonna do.
bricktron
(^^ not my car)
erio
04-04-2017, 07:37 PM #15
this is mine
1999 S210 Edc pump. 7.5mm dieselmeken element.
HX35W turbo, custom map.
Brakes 330mm 4 piston brembo CL500, bolt on fit. Longer brake lines. 3mm spacers.
260km/h
2.1 boost for now.
16 inch steel wheels with 20mm spacers.
erio
this is mine
260km/h
2.1 boost for now.
