STD Tuning Drivetrain w124 300d turbo getrag gearbox swap
PedroFerreira
09-21-2015, 07:58 PM #1
hello im planing to put  a getrag gearbox into my w124 300d turbo.now i have the 722.3 stock gearbox...
what parts i need to make the swap?i whant to keep whith the same diff... can i use the same transmition shaft?
thanks for help
PedroFerreira
thanks for help
PedroFerreira
09-21-2015, 08:07 PM #2
can i use om605 flyweel and cluntch (reinforced)?
PedroFerreira
09-21-2015, 08:48 PM #3
If Getrag with 1:1 5th gear, then the original diff ratio is good. The manual trans will be shorter, requiring a longer drive shaft.
Single mass flywheels work with single mass transmissions, dual mass flywheels work with dual mass transmissions. The Getrag 5 speeds came in both flavors.
PedroFerreira
09-22-2015, 04:11 AM #4
can i use single mass or dual mass depending the the car it come ou i can use dual mass in all getrag?
what is max power that gearbox can handle?
PedroFerreira
09-22-2015, 11:34 AM #5
The 717.404 is single mass, 717.450 is dual mass
PedroFerreira
09-22-2015, 12:28 PM #6
Thanks for help,
what is the max power that can take? 350hp is safe?
PedroFerreira
Thanks for help,
09-22-2015, 05:06 PM #7
I'll let you know :-)
