STD Tuning Engine Setting up a superpump
RickyE
10-03-2015, 04:59 AM #1
Hello, i recently got my pump with dieselmekins 7.5mm elements fitted, however i cant get it to tun right, it wont tick over for me and when i do get it to tick over its hanging the revs.
When im holding revs on it its running smoothly.
Can anyone help me set it up. I have tried screwing the tickover up, but the screw is nearly through the nut and it still wont tick over
Sorry if that doesnt make any sense, hopefully someone understands
Cheers
RickyE
Cheers
minim
10-03-2015, 05:58 AM #2
I'm not sure I understand, but did you connect the Alda to the pressure side of the intake? Does it move during boost?
minim
10-03-2015, 07:21 AM #3
take it out , sincronize it and it will be fine...
TurboTim
10-03-2015, 09:00 AM #4
What he said...
76 300TD custom lots of stuff
TurboTim
What he said...
gary andrews
4x4 builder
48
10-03-2015, 12:59 PM #5
take it out check your not 180 out put back in 10-11 deg after, sounds like timings out
discovery 2 fitted om605 m pump 7.5 elements 300 turbo at mo
c250 std at mo
off road buggy fitting om 606 turbo ? supercharger ? to follow
www.gaz-fab.co.uk www.facebook.com/gazfab
gary andrews
c250 std at mo
RickyE
10-04-2015, 04:26 AM #6
No alda on it, its a na pump
Will try that, it runs fine on boost and have had it driving, but will try taking it off and timing it up again, cheers
RickyE
