STD Tuning Engine Holseth HX30W Pressure side V-band
minim
10-04-2015, 04:11 PM #1
Anyone got an idea of what clamps to use on the Holseth HX30W on the pressurised air output? It looks like something between 2.25" and 2.5" but I'm having a hard time finding something that fits.
[Image: IMG_1303.JPG]
[Image: IMG_1304.JPG]
[Image: IMG_1305.JPG]
[Image: IMG_1306.JPG]
Some size info sheet I found at frozenboost for reference.
[Image: vband_ring_specsheet.gif]
minim
TurboTim
10-05-2015, 06:42 AM #2
I just ground mine down and used regular silicone coupler. You can find that elbow on ebay though if you look.
This post was last modified: 10-05-2015, 06:42 AM by TurboTim.
76 300TD custom lots of stuff
TurboTim
10-05-2015, 11:08 AM #3
I welded a pipe onto mine so I could use a silicone adapter. So basically the same as turbo tim
Tito
10-05-2015, 02:30 PM #4
I also ground mine down to a little hump so the hose couldn't pop off.
This post was last modified: 10-05-2015, 02:31 PM by Tito.
Tito
minim
10-05-2015, 05:02 PM #5
http://m.ebay.com/itm/121389328525?_trkp...mwBanner=1
Something like this then? Was going to use 2.5 Pressure piping.
minim
Tito
10-06-2015, 01:15 AM #6
That should work fine.
Tito
10-06-2015, 06:02 AM #7
You need a 2.5" V-band clamp..
minim
10-06-2015, 06:53 AM #8
According to the document I attached the 2.5" is 1" to big..
minim
