STD Tuning Engine HE351 Have T4 connector?
deviance
HE351VE
88
12-09-2015, 12:11 PM #1
I don't know in english.
Thank You!
deviance
Thank You!
TurboTim
12-09-2015, 12:15 PM #2
If you are talking about exhaust flange its more like a T3.5. Its not really T3 flange or T4. Its wider then T3 but not as tall as T4
76 300TD custom lots of stuff
TurboTim
deviance
HE351VE
88
12-09-2015, 12:20 PM #3
So is it bad if i cut T4 with CNC?
deviance
hents99
12-09-2015, 12:39 PM #4
(12-09-2015, 12:20 PM)deviance So is it bad if i cut T4 with CNC?
I can give you 10mm steel flange for this turbo.
hents99
12-09-2015, 12:53 PM #5
It's a T4i. Same port size, different bolt pattern.
12-09-2015, 01:22 PM #6
T4 can be made into a t4i, but if you already have to cut one, id go ahead and make it correct. Same flange as most hx52
