STD Tuning Engine Help - PS pump removal
ho55
03-18-2016, 10:48 AM #1
How on earth do you get the PS pump removed on a OM606.962 (W210)
You cant get to the mount bolts until you have the pulley off, and my pulley wont budge.
The centre nut is stuck. I have tried with the bolt on to hold it, with an air gun and a bit of heat.And stripped the teeth of 2 sockets.
Is there any way to get the pump off without removing the pulley?
This post was last modified: 03-18-2016, 10:49 AM by ho55.
ho55
AlanMcR
mind - blown
400
03-18-2016, 11:14 AM #2
Might it be a lefty nut?
AlanMcR
ho55
03-18-2016, 11:16 AM #3
Ok ignore this. Have done it.
I thought the middle nut had to come off, but realized that the pulley pulls off when the 3 bolts are removed.
ho55
baldur
Fast
511
03-18-2016, 11:47 AM #4
Nothing a dab of dynamite won't solve.
Baldur Gislason
baldur
Baldur Gislason
Tito
03-18-2016, 05:08 PM #5
You're not first one to make this mistake... I spend 2 days figuring out how to get the middle crankshaft bolt out but then I realized I needed to loosen the bolts around it to get the pulley off Big Grin
This post was last modified: 03-18-2016, 05:08 PM by Tito.
Tito
