STD Tuning Engine DPUK horizontal alda
hummermaniac88
09-16-2016, 08:57 AM #1
Hi guys,
Recieved the DPUK HORIZONTAL ALDA  kit for my w463 om606 project with a om603 built m pump. Having trouble figuring where all the parts go. It different than dieselmeken's kit. Someone have experience of have picture.
hummermaniac88
Hi guys,
hummermaniac88
09-16-2016, 09:00 AM #2
I'm trying identify in the dpuk kit what replaces the circled part in dieselmeken's video screenshot.
hummermaniac88
09-16-2016, 12:34 PM #3
that thing operates by controling(restricting) the rack movement with the stop lever, which in normal operation will pull the rack back in switch of mode.
one of the parts is to be assembled in place of the manual switch off control , the other with the actuator is to operate the lever.
then u have (should have) the other parts wich are to limit the min and the max, basically are mechanichal stops.
but looking at the thing , it looks like u have too much parts.....
puzzle it
puzzle it
hummermaniac88
09-19-2016, 06:15 PM #4
Thanks for the info, but those two plates are still bothering me. Can't see seem to fire out how they fit onto the pump. Dpuk isn't responding either.
hummermaniac88
09-20-2016, 12:31 AM #5
i haven´t seen their system, in my hands ... i use the dieselmeken system and this should be very similar cause dpuk is a kind of parter with this fellas.
but sometimes can be a bit puzling .
in the end u must have the 2 functions this device alowws. limit max rack without boost and limit max rack irespective of boost. once u have this 2 functions , thats it.(even if u have extra parts in the end)
good luck
good luck
Nev
09-23-2016, 01:54 PM #6
Same ALDA on my 602 pump. Hope that helps.
[Image: 14264904_10157286601925276_3524806345887...e=58399484]
This post was last modified: 09-23-2016, 01:55 PM by Nev.
Nev
NZScott
HX30W 73/44mm
398
09-23-2016, 08:31 PM #7
That's a vertical one so not the same unfortunately Wink
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
Nev
09-24-2016, 06:49 AM #8
(09-23-2016, 08:31 PM)NZScott That's a vertical one so not the same unfortunately Wink
Blush Blush
Nev
Blush Blush
