STD Tuning Engine 314 nozzles
314 nozzles
314 nozzles
blankman812
09-24-2016, 04:06 PM #1
I put a set of 314 nozzles in my 616 and it cleaned up the idle but has seemed to have lost power my stock injectors were 240 nozzles I was led to believe the 314s were approx 15% over duty am I confused or missing something here
blankman812
NZScott
HX30W 73/44mm
398
09-24-2016, 05:33 PM #2
Sorry mate, 314s were the later nozzles, 315s are for a non-MB engine and are meant to flow more.
But don't forget in an IDI the injector flow is largely irrelevant. If your 616 is NA still then I doubt you would gain all that much anyway.
But hey, new nozzles of any type will make an engine run better Smile
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
blankman812
09-24-2016, 05:48 PM #3
It has a kko3 turbo and I'm working on the pump now it is intercooled and I'm ready for more fuel
blankman812
NZScott
HX30W 73/44mm
398
09-24-2016, 08:06 PM #4
Sounds like you're pretty well set up then. Enjoy your new nozzles Wink
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
blankman812
09-24-2016, 09:03 PM #5
The new nozzles didn't work I need larger nozzles....
blankman812
NZScott
HX30W 73/44mm
398
09-25-2016, 01:56 AM #6
If the engine runs they're working Tongue
You don't need bigger nozzles. People get 500+ hp from 606s on 314s so...
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
09-25-2016, 10:56 AM #7
The #315s are the known drop in replacements which flow around 15% more fuel. The #314s, #265s, and #261s flow around the same amount of fuel, with tiny differences in which highly unlikely any person would ever know any difference.
blankman812
09-25-2016, 12:44 PM #8
I see you all aren't reading what I am trying to say I went to the 314 form a 240 and I have lost power something is wrong or am I missing something the factory injector created more power it was a little snooker also the 314 start up clean and stay clean and my egts are way lower it feels like I'm only 3/4 throttle now
blankman812
09-25-2016, 08:04 PM #9
You should not have lost any power. Something is apparently not "right". Did you pop test them before installing them?
