STD Tuning Drivetrain om603 what tranny use ?
jarow123
10-10-2016, 03:23 PM #1
My plans with om603 by 7 mm element go on the 300PS, the question is which gear box is strong  for use?
jarow123
benzguy
10-10-2016, 07:36 PM #2
The strongest gear box you can use in a 603 with a single mass flywheel is the getrug 5 speed from a w201 16V the 717404
benzguy
jarow123
10-11-2016, 04:18 AM #3
thanks and gear box from c250td 717.460 is good or no ?
jarow123
Evgeniy1987
10-11-2016, 07:56 AM #4
Are you sure a 716.649 is not stronger ?
Evgeniy1987
benzguy
10-11-2016, 05:30 PM #5
I don't know any thing about the 716649 because it never came to the USA I do know that you must have a single mass flywheel for a super turbo the dual mass flywheels will come apart if you use it in a super turbo engine
benzguy
capflya
Dreaming of a VNT
309
10-15-2016, 08:10 PM #6
I think F.R.A.S. and diesel pump U.K. Have a single mass flywheel conversion for dual mass transmissions? Might just be for the BMW transmissions though I forget all the details...
capflya
