STD Tuning Engine OM606 300HP TURBO
OM606 300HP TURBO
OM606 300HP TURBO
  • 1 Vote(s) - 5 Average
Val7
03-07-2017, 12:42 AM #1
Looking for the best turbo for 300hp om606.962, ive read that hx35 is good choice but havnt really seen a solid answer.
Val7
hents99
03-07-2017, 01:45 AM #2
HX35 is bit laggy for 300hp target. HY35 has smaller turbine housing and should be more comfortable to drive than with HX35.
hents99
03-07-2017, 02:40 AM #3
In the 606, the HX35 WG with dual scroll #12 turbine housing works great. As mentioned above is a bit laggy , but that will happen with any turbo of the same size Compressor and turbine(core inertia). This was based on a mod i made, pump is a 7.5 150cc, engine gave 320HP at whells.
In my opinion the HX is a cheap solution, and for the 606 the #10/11 turbine housing would be perfect, the compressor swapped by a billet wheel, (those mamba or kinugawa etc) slightly bigguer so that the housing has to be machined to mach perfectly.
BUT IF budget is not a problema go for KKK EFR or GTX series, or a pair one in each 3 cylinders...
regards
regards
hents99
03-07-2017, 04:17 AM #4
Here's hx35 on om606 g wagen
https://m.youtube.com/watch?feature=yout...s6hpDr8fn4
hents99
