ML270CDI 722.661 into W124
Anyone know if the ML trans can be used in RWD application (w124) easily? I have seen pictures of the transfer case removed but I am not sure if the driveshaft yoke can be easily attached to the output shaft?
The ML270CDI 722.661 is the easiest strong box I can find locally, there are no C270 CDI's around and all the v8 transmissions are much more expensive.
Thanks
