STD Tuning Engine OM60x timing device information
baldur
Fast
511
01-15-2018, 08:33 PM #1
Does anyone know where I can find specs for the operation of the timing device on the various OM60x engines?
What I'm specifically looking for is information on the timing curve they are expected to operate with, at what engine speed the timing should start getting advanced, at what speed there should be the full amount of advance and how many degrees of advance does the sprocket add at full speed.
Baldur Gislason
baldur
Baldur Gislason
Evgeniy1987
01-16-2018, 10:38 AM #2
Full geometrically possible advance - measured by eye and a geo-triangle - is about 20 - 25 cranck-degrees
This post was last modified: 01-16-2018, 10:39 AM by Evgeniy1987.
Evgeniy1987
baldur
Fast
511
01-16-2018, 11:13 AM #3
Ok. I am finding that my engine definitely wants less advance at low speeds now that it has a 7.5mm pump, but although acceleration is good it feels flat up top and has high EGT so I'm thinking it may need more high speed advance.
Baldur Gislason
baldur
Baldur Gislason
Turbo
01-16-2018, 04:15 PM #4
How did you come to the conclusion -"I am finding that my engine definitely wants less advance at low speeds now that it has a 7.5mm pump" and at what rpm did find?
last I spoke with diesel meken on phone they had made so it could advance 5 degrees more, but if you run high rpm it will be a limeted factor, guy in the tractor pulling are doing 50 degrees but the advance do not change and I guess it is why they needs to take it really easy when they spin iyt up to boost
Turbo
baldur
Fast
511
01-16-2018, 05:48 PM #5
The engine pings like a machine gun at low RPM unless I retard the pump. I do however have it running smoothly at higher speeds and loads but it still is a bit rough at low RPM. Leading me to believe it would be of benefit to pull a couple of degrees out up to 2000RPM.
Baldur Gislason
baldur
Baldur Gislason
addi.bigg
OM605; 7,5mm elements
94
02-13-2018, 05:11 AM #6
(01-16-2018, 05:48 PM)baldur The engine pings like a machine gun at low RPM unless I retard the pump. I do however have it running smoothly at higher speeds and loads but it still is a bit rough at low RPM. Leading me to believe it would be of benefit to pull a couple of degrees out up to 2000RPM.
That could be interesting for me too. I also have noise above 2000rpm that dissapears above that.
Maybe that is because of the 7,5mm elements.
addi.bigg
baldur
Fast
511
02-13-2018, 07:16 PM #7
(02-13-2018, 05:11 AM)addi.bigg
Yes, my engine sounded much smoother with 6mm elements. It was suggested to me to try special injection nozzles that reduce pinging. I will post an update when I have tested those.
I also want to do some development on the pump timing, find the curve that gives me the best performance.
Baldur Gislason
baldur
Baldur Gislason
addi.bigg
94
02-14-2018, 01:04 AM #8
(02-13-2018, 07:16 PM)baldur
 Could you please make a cold start video of your car? I've made some yesterday of mine and I would like to compare the two is possible.
addi.bigg
