STD Tuning Engine Aftermarket oil cooler for om606. Sandwich plate necessary?
05-22-2018, 10:24 AM #1
Is a thermostatic sandwich plate necessary for using a larger oil cooler with the om606 or do peope just add fittings to the end of the existing oil lines to/from the filter assembly?
Thanks
606110
Thanks
AlanMcR
mind - blown
400
05-22-2018, 12:47 PM #2
What you are asking isn't entirely clear. The oil filter block has a built in thermostatic switch. There were a number of different oil filter + cooler designs for the OM606a. If your filter has hoses, then the flow should already be thermostatically controlled. The factory coolers seem well sized for the oil line size. Adding a bigger cooler may not make much of a difference. You could add a more powerful fan if you think that the cooling is insufficient.
AlanMcR
Mr.Emo
Nissan Patrol -> 606 conversion.
69
05-23-2018, 03:36 AM #3
Yoshifab has AN10 fittings that go into the original oil lines from the filter. Then you can use any cooler you want. Smile
Mr.Emo
