STD Tuning Engine Opinion regarding the turbo
miguelrocha
02-04-2020, 02:40 PM #1
Friends that turbo prefer for an Om605 pump 7.5 dieselmeken
- Borgwarner S200SXE S257
- Holset HX35 exhaust part 12cm
Thanks
miguelrocha
Thanks
wiseman89
02-04-2020, 03:24 PM #2
Ive read alot on other forums that the Borgwarner turbos are better and more efficient than the Holset. But the holset is cheaper.
It depends on you budget, Id go BW.
wiseman89
Mallinman
02-04-2020, 04:32 PM #3
I’m running the s200 with 7.5mm elements and it goes very well. It’s on a custom intake and exhaust manifold to maximise the flow but it Really lights up well and fast. . And that’s in a big pick up truck.
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
miguelrocha
02-04-2020, 08:23 PM #4
(02-04-2020, 04:32 PM)Mallinman I’m running the s200 with 7.5mm elements and it goes very well. It’s on a custom intake and exhaust manifold to maximise the flow but it Really lights up well and fast. . And that’s in a big pick up truck.
What A / R are you using?
Single Scrool A / R 63 Or TwinScrool A / R 78? Thanks
miguelrocha
Mallinman
02-05-2020, 02:46 PM #5
Single scroll. I swapped the exhaust out to a .48 a/r. I need as much low down grunt as possible. I tow a lot with it.
Borgwarner S200
Mallinman
Borgwarner S200
