STD Tuning Engine Source for Bosio Nozzles and Shims
zeeman
05-18-2020, 11:58 AM #1
Looking for source for SD - 310 Bosio nozzles and shims. This is the nozzles my previous injector rebuilder was using, who doesn't do it anymore.
This post was last modified: 05-18-2020, 10:26 PM by zeeman.
zeeman
X Double Dot
05-19-2020, 07:03 AM #2
(05-18-2020, 11:58 AM)zeeman Looking for source for SD - 310 Bosio nozzles and shims. This is the nozzles my previous injector rebuilder was using, who doesn't do it anymore.
so out of curiosity, are the 310's what you plan to use in a 606.962?  I ask because i tried some 310 monarks initially before switching to the 314 (by Firad) because i heard that was what was supposed to be in a .962.
not at all what you asked, but ID parts has the 314 Firads (https://www.idparts.com/firad-injector-n...-3085.html).  Figured i'd post it as reference for someone else looking
X Double Dot
zeeman
05-19-2020, 11:32 AM #3
X Double Dot
The company that was rebuilding my injectors DDW were using the Bosio 310's in the 606 IDI injectors, they claimed they put out more fuel. I am not sure if this is true or not, what is the difference between the 310 and the 314 volume wise ?
zeeman
X Double Dot
