STD Tuning Engine HE200W 5cm turbo for the OM617 with stock IP
300SD
11-17-2023, 03:09 PM #1
Hi to all,
I'm new to the forum: First time posting but long time reader.
I'm been working on diesels and Mercedes OM617 engines for almost 20 years now.
I wanna upgrade the turbo in my OM617.
I have a quick question regarding what turbo will be best for the OM617 with stock IP (5.5mm)
with the ALDA deleted and automatic transmission.
Reading online I see 2 choices for the stock IP (Please feel free to suggest any other non-VNT
turbos suitable for a stock OM617):
Holset HE200W 5cm
and
Holset HE221W 5.5cm
Does any body have any experience with any of these 2 turbos with those particular turbines sizes
(5cm & 5.5cm) in the OM617?
I'm thinking of going with the HE200W 5cm.
I live at almost 4000 feet elevation.
I mostly drive in the 2000 to 3000rpm range and planning to run at about 15 psi of boost.
I hardly ever go over the 4000 rpm range but I read from a turbo test excel sheet that the HE200W
5cm will be fine over 4000 rpm if run at about 15psi to mantain a Boost/DP ratio of 1:1.1 with
stable EGT's.
What do you guys think of the HE200W 5cm in the OM617 with stock IP and automatic transmission?
Is the Holset HE200W 5cm turbo a good choice in my case?
Thanks
300SD
Hi to all,
Holset HE200W 5cm
and
Holset HE221W 5.5cm
stable EGT's.
Thanks
Kevy
01-21-2024, 11:37 PM #2
Don't delete the ALDA, there is no good reason to.
HE200W for the stock pump.
Kevy
