STD Tuning Engine VNT 190d
VNT 190d
VNT 190d
Jtn190D
MERCEDES DIESEL POWER!
192
12-28-2009, 07:30 PM #1
Hay guys any thoughts on adding a VNT/VGT turbo on my car? like what would it involve? would it be worth it? and how much more power could i get out of my car?
Jtn190D
12-28-2009, 10:56 PM #2
It will make the same power as any other turbo of a similar size, just sooner in the RPM range.
The biggest issue in your car is clearance; installing any custom turbo in a W201 will be a tight fit, especially if you need to use an adapter plate. Making a tube that rotates the mounting point up 90* will make a lot more room to work with.
You'll need to make adapters for everything- exhaust manifold, exhaust system, intake, compressor outlet, oil supply, oil draining and control of the vanes. There is nothing known that will bolt-in.
If you search, there are threads on many different control and mounting methods.
This post was last modified: 12-28-2009, 10:57 PM by ForcedInduction.
George3soccer
12-30-2009, 02:56 PM #3
This is what I am going through adapting the stock parts to a custom setup basically. Everything basically has to be altered not a problem because when I do it. It tends to be better then stock in my opinion.
George3soccer
Jtn190D
192
12-30-2009, 05:33 PM #4
What engine are you doing this on?
Jtn190D
George3soccer
01-03-2010, 09:49 PM #5
om602 NA
George3soccer
om602 NA
