STD Other Projects Majesty78´s Majestic ;-)
  • 3 Vote(s) - 3.67 Average
Pages (3): Previous 1 2 3
Turbo
05-30-2013, 02:34 PM #101
Nice work alex
though little hard to see scale of the diagrams and compare
(05-30-2013, 01:54 PM)majesty78 IC hoses connections is very simple.
Due to the 800mm with of the core + the with of the end tanks, the cooler is exactly as broad so that the meet up with the stock hoses position which leads to and from intercooler.
So there are just 2 pieces of straight aluminum welded on the rear of the end tanks and then connected to stock hoses. (removed the "click" adpaters which blew off several times)
The bumber is cut, on above pictures it is just the "raw" built to take it for test drive and see results.
The crash bar is not cut, this is still stock.
There will be some of this stuff used:
[Image: gitteryqq0g.jpg]
Turbo
Nice work alex
majesty78
06-08-2013, 08:59 AM #102
Car is sold, so here the last pictures I made today:
[Image: dsc_02421oy4g.jpg]
[Image: dsc_0243ctz0k.jpg]
[Image: dsc_0253zzlr2.jpg]
[Image: dsc_0244hxxkj.jpg]
[Image: dsc_02458yzf7.jpg]
[Image: dsc_024676yjt.jpg]
[Image: dsc_02473oaea.jpg]
[Image: dsc_0248gwacu.jpg]
[Image: dsc_0250r6abx.jpg]
[Image: dsc_0251okze1.jpg]
[Image: dsc_0252u2bog.jpg]
majesty78
06-08-2013, 11:58 AM #103
Whats next?
Whats next?
majesty78
06-08-2013, 12:13 PM #104
For the meanwhile a Seat Leon Cupra "R", 1.8T 225hp GASOLINE ^^
majesty78
06-08-2013, 01:27 PM #105
Them are some awesome reflections of that wavy steel wall. Nice shotz
k1b3r
01-09-2014, 07:31 AM #106
Read PM please.
k1b3r
Read PM please.
01-09-2014, 07:54 AM #107
It looks stock at first glance, that's great!
majesty78
01-09-2014, 08:57 AM #108
New owner has put 7.000km on it since he has it.
Needed 2 sets of 265/35/18 rear tires *lol*
He seems to like it. Let it warm up, then WOT as much as possible.....
majesty78
k1b3r
05-01-2014, 06:06 AM #109
majesty78 hello . i need your help
I removed the catalysts
bought equipment for chip-tuning.
I raised through the program limit torque and boost pressure.
Now I have a couple of questions. How to disable EGR? through the map or via a special key in the ecu software ?
Why raise the pressure in the common rail, what effect?
what normal peak pressure in CR ?
how much percentage I can raise the pressure in CR ?
May be you have OLS file for ecu software ? difficult to make changes without knowing the values on the graph.
Thx
This post was last modified: 05-01-2014, 06:11 AM by k1b3r.
k1b3r
Thx
 3 Guest(s)
 3 Guest(s)
