STD Tuning Drivetrain W124 OM606, manual setup
Pages (2): Previous 1 2
mantahead
05-08-2011, 05:14 PM #51
hi, how much for flywheel and clutch kit?
i was talking to a guy who says he can rivet on a competition liner to my standard clutch and maybe put stronger springs in pressure plate. It is very cheap so i might give it a go.
mantahead
Diesel-Frank
05-08-2011, 05:40 PM #52
(05-08-2011, 04:11 PM)jeemu
(05-08-2011, 07:26 AM)Diesel-Frank
(05-08-2011, 07:15 AM)jeemu Hi. I ordered my friend 605 + short axle tranny special made FW
Original sensors work.
NICE!
what prussure plate and disc is on the picture??
Hi. Sachs Race pressure plate to Bmw m3 and Mercedes 250d disk.
same pressure plate found my own car.
sachs 765??
Diesel-Frank
NICE!
sachs 765??
mantahead
05-09-2011, 04:14 PM #53
hi,
a guy told me that a c36 amg clutch is the same fitment as my om605, its 26 spline and 240mm and lots of performance ones available. Anyone got any way of double checking this??
wayne
mantahead
hi,
wayne
jeemu
457
05-10-2011, 08:03 AM #54
(05-08-2011, 05:40 PM)Diesel-Frank
(05-08-2011, 07:26 AM)Diesel-Frank NICE!
sachs 765??
No. Its -618
jeemu
sachs 765??
No. Its -618
Diesel-Frank
05-10-2011, 04:40 PM #55
i need the gear shifter to my 717.450
anyone have one for sale, or is there other parts i can use??
the tranny is from a 300CE-24, and i will mount it in my w124.
Diesel-Frank
Diesel-Frank
05-11-2011, 12:42 PM #56
(05-10-2011, 08:03 AM)jeemu
(05-08-2011, 04:11 PM)jeemu Hi. Sachs Race pressure plate to Bmw m3 and Mercedes 250d disk.
sachs 765??
No. Its -618
what is the difference between 765 and 618??
Diesel-Frank
sachs 765??
No. Its -618
jeemu
457
05-11-2011, 01:42 PM #57
(05-11-2011, 12:42 PM)Diesel-Frank
(05-08-2011, 05:40 PM)Diesel-Frank sachs 765??
No. Its -618
-765 is 240mm and -618 is 228mm. 40bar difference those spring force.
jeemu
No. Its -618
johan84
05-12-2011, 04:58 AM #58
i found
a clutch company that makes clutch kits for many merc,s
al types 300e and also a 240d, 260e
http://www.specclutch.com/products
also for 717,430, 717,433, also slk 230 types
i did not now the company
but the the site lookes nice
i not found info about the torque capacity but i will send a mail
the also sell twin clutches and flywheels
if the pressure plates ar not good maybe only a clutches plat is and option
here for 300e 1987 717,430 transmission
http://www.specclutch.com/cars/Mercedes/...987/Single
johan84
i found
johan84
05-12-2011, 03:54 PM #59
got a mail back from the specclutch company
this clutch kit : http://www.specclutch.com/cars/Mercedes/...987/Single
the spec 5 clutch kit can handle 725nm cost: $789,-
the have and option with superclamp pressure plate
915nm cost: $869,-
it is for a e300 1987 gearbox i the flywheel will fitt on a om60X
is it???
gr johan
This post was last modified: 05-12-2011, 03:55 PM by johan84.
johan84
915nm cost: $869,-
is it???
gr johan
Diesel-Frank
05-13-2011, 05:10 PM #60
(05-05-2011, 12:00 PM)willbhere4u On this thread you can see the solid mass fly wheel I am using on my om603 6spd project it is for a sprinter 2.2 CDI to replace the original dual mass flywheel! http://www.superturbodiesel.com/std/thre...ch-options
Notice the pilot bearing in the flywheel not the crank shaft it's for the shorter style input shaft transmissios
today i ordered this clutchkit, but i will modify the FW to fit the 765 pressureplate!Smile
This post was last modified: 05-13-2011, 05:11 PM by Diesel-Frank.
Diesel-Frank
Diesel-Frank
05-14-2011, 03:58 AM #61
what is the difference between the clutch disc in the Valeo kit i ordered, and the C250 turbodiesel disc??
wondering if i need to order the C250 disc...
Diesel-Frank
HoleshotHolset
05-16-2011, 09:24 AM #62
Wow...now that is a work of art.
I shudder to think what a shop in the US would say if I needed such a thing (with the hall effect features included for the sensor...) made for my OM606. Rolleyes Cubic dollars.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
Diesel-Frank
05-21-2011, 03:34 PM #63
can i use the disc i have ordered with the flywheel(ebay link)??
or is the c250dt disc better??
how thick is the C250dt disc??
i see jeemu`s custom flywheel for the 618 plate is flat all over, and muuris flywheel for the 765 plate is higher in the center of FW, why?? i will use the 765 plate.
Diesel-Frank
Diesel-Frank
06-27-2011, 10:17 AM #64
anyone know how thick the C250 turbodiesel disc is??
Diesel-Frank
swampmonkey
hx40 super
280
04-15-2013, 12:34 AM #65
Have a 300ce 12v + 717450 trans available for like 600$
Good price? And how much power can it handle?
and what is the easiest way to get a clutch that can handle like 250-300hp?
Sprinter clutch+sinter or something else? Supposed to be a daily driver.
Cheers and thanks in advance
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
 9 Guest(s)
 9 Guest(s)
