5 cylinder M Super pump testing, fitted with M75 Floyd 7.5mm elements
(05-19-2010, 09:12 AM)Rudolf_Diesel(05-19-2010, 08:48 AM)winmutt * winmutt waits patiently for the bottom to fall out of the euro...
I know what you mean buddy!
Fortunately the next phase of the project is all available in the USA...
A Tremec TKO 500 5-speed transmission...more deatils and a seperate thread to follow.
OK, so when can someone replicate this on an OM603 pump...?
(06-02-2010, 12:01 AM)tomnik to be honest, not too exciting up to now.
I made an IP and my friend is running it in his n/a.
First thing was that the car smoked a lot and was nailing (in combination with power loss) beyond let's say 3500-4000 rpm and pedal depressed. Then we decreased the full load and everything was perfect. No power gain at low rpm but beyond 3000 the engine climbed up to 5400 like hell. He has the 3.8?? rear end and top speed is limited by rpm max.
Now this lazy bone is not able for weeks now to play with timing. Actually the timing is set at 8 deg before TDC! This was how it came up when he installed the IP. In my opinion this is far too late but he can't find the time to change it.
Also those are the rest of the 7mm crap elements I had sitting around where we took the 5 best for the IP.
I will up date the progress as soon as he gets further.
Tom
(06-01-2010, 09:31 PM)jonbobshinigin I know I have seen this addressed briefly before but: What would something like this look like on a NA (Naturally Aspirated) 617?
update:
yesterday night we set the timing to 24deg TDC.
I was completely wrong with my thoughts to retard the timing with larger elements. 24-25deg is the way to go.
After changing the timing my friend's 123 coupe with 617 n/a engine (and 650.000 Km on the clock) is now comparable with an average 126 with 617 Turbo. My friend was like and I fear that he will never give back this IP any more. Absolutely no issues with smoke or engine run, just way faster than before. I was a little shocked of the performance of a n/a 617.
Let's see what the next days bring regarding consumption etc.
I'll try to find an other n/a M-IP.
Tom
Tom
(06-11-2010, 08:22 AM)Deni How can you go faster without more air?
diesels make there power with fuel but they get hot that's when air is needed to keep them cool
If you add boost with out more fuel it wont make almost any more power!
Hey, tom I've got an interesting proposal for you! I have got an M-pump lying around first off the bad news front delivery valve holder has broken off with threads inside and damage to the IP Block. So question one could fix that and rebuild the pump with larger elements, or barring that if I could get it fixed I could mail it to you for the larger element treatment. Either way please email me at meareweird@yahoo.com to discuss.
Also slightly more on topic what are the EGT's looking like on that N/A and obviously this will lower engine life considering the unequal heating and ovalation required for the pistons as described here http://en.wikipedia.org/wiki/Indirect_injection any thoughts on this?
Hi Tom!
--Are you coming to the UK in the next couple of weeks or so...?
--If so, I have a couple of 'M' type for 617 just gathering dust, they are all in good running order, and are just spares....
You're welcome to them, as I would also like to try the M75 elements in my N/A engine too....
(06-11-2010, 02:16 PM)meareweird Hey, tom I've got an interesting proposal for you! I have got an M-pump lying around first off the bad news front delivery valve holder has broken off with threads inside and damage to the IP Block. So question one could fix that and rebuild the pump with larger elements, or barring that if I could get it fixed I could mail it to you for the larger element treatment. Either way please email me at meareweird@yahoo.com to discuss.
(06-11-2010, 02:31 PM)Alastair E Hi Tom!
Hi,
I answered to your post already.
Repairing this pump yes, but just to see if it is possible, not to use it afterwards on the engine. It might be cheaper to get a complete used IP instead of repair or buying an IP block and transfer all the parts.
Shipping this IP extends the actual value.
For element swap and adjustment DervTuning in Maryland is the guy to contact. He knows what to do and uses my elements.
On topic: This was just to see how a n/a engine reacts on the larger elements. I did not expect that power increase without the possibility of additional air. This is the only thing we wanted to see, no EGT observation (no sensor in this engine), no thoughts about EGT at all.
What my friend noticed while having the IP very late at 8deg was fast temperature increase and higher temps while driving but this is not a surprise regarding the 8deg.
Tom
Hi Tom,
--That sounds like a good plan....
IF its any help, I have an injection-shop guy local to me, who is pretty friendly, known him for years, and I'm sure I could persuade him to let me tinker with a pump on his Test-Bench, one Saturday morning....
--So if you did get a pump built up with 7.5's and set it up, I could alter it for fuelling etc, on the engine, and when I'm happy its at its best for power and low-smoke, in the real-world, on an engine, I could then re-measure its delivery at the two-speeds in an attempt to derive some data for a Test-Plan, which would then be easy for any Good Diesel-Shop to duplicate...
--It would also go some way to developing a Test-Plan for the Turbo motor using the 7.5's, as the N/A requirements will be much the same in the Important, low-revs OFF Boost phase with regards to Smoke emissions....
---Just an idea.....
(06-16-2010, 01:24 AM)12mpghwy So whats the total cost of this treatment on an OM603 IP?
Yeh, a price, even an estimate, for an om603 pump would be great! That way I can start saving, or selling stuff...
So, as a rough guide for guys reckoning on installing the M7.5 Elements, consider like this-
Elements are 60 Eur each, and you'll need 6 for a 6 pot engine, so thats 360 Euro Plus Shipping and any Duty at Customs etc, so may be as high as 450 Eur,--You'll have to check-- so thats gonna be around $550 USD, as a rough guide, All according what the exchange-rate is.......
-That is just to get the actual parts needed. The Pump will need full dismantling to remove old elements and install the new, as well as select new rollers for 'Phasing' each new element.
The pump will then be built up and set to run on a Test-Bench where the fun begins!
Obviously, on full dismantling of the pump, things like the Cam bearings will be replaced if its a high-mile pump, or they are in any way suspect, as the Loadings on the Cam the M7.5 elements will generate can be higher than the original 5.5mm elements, as well as any other parts found to be worn. It goes without saying seals and 'O' rings will need replacing.
The Governor will have to be re-set to give the fuelling requirements of the particular engine type and then Customised to the Customer's requirements....
--If an 'ALDA' is required, this is itself another 'Project' involving modification if a N/A 'M' type is used.....
To Fully Strip, Clean, select rollers, build up a Bosch 'M' type is gonna take at least half a day to do right, thats Before it goes anywhere near the Test-Bench.
Figure on at least 2 hours bench time to set the pump up.........
All the above assuming the pump supplied is in sound physical/mechanical condition to start with!
Tomnik supplies the Custom Made M 7.5 'Floyd' Elements from Germany where he had them specially made to the required spec., but its 'DervTuning' who does the hard job of installing and rebuilding/setting up the pump for the Cust. in the U.S.A. I believe he is the Only one in the U.S. that has any experience with these parts and this application......
Best P.M. DervTuning for a price on his work.....
Are there ways to have such a swap of elements to be done in Germany?
I live in the Netherlands and would be interested to gain a little more power.
Peanuts, regarding what will turn out if the small rest of the job will do well.
Jokin', 60 Eur/element from my side.
Contact Derv for the swap and set up.
and even mini peanuts compared to the beautiful engine of Rudolf.
Tom
[/quote]
(06-21-2010, 03:17 PM)plurkje Are there ways to have such a swap of elements to be done in Germany?[/quote]
Tom
For the Netherlands it makes sense to send the IP to me (Germany) for the complete swap and adjustment.
What type of pump? M or MW? 5 or 6 cyl.? Turbo or n/a?
(I will be on a 2 weeks holiday trip starting next weekend)
Tom
Tom
(07-19-2010, 10:41 PM)jonbobshinigin Any update on a 603 pump?
Dervs inbox is full...I guess I'd like to read about a 603 success because I cannot afford to be a tester at this point. Plus get another of my cars running so that I'll have a backup. Plus get and intercooler. Plus a pyrometer, larger turbo, and install the Euro W140 Exhaust Manifold I got 6 months ago that is sitting on the shelf.
(07-22-2010, 08:50 PM)jonbobshinigin Dervs inbox is full...I guess I'd like to read about a 603 success because I cannot afford to be a tester at this point. Plus get another of my cars running so that I'll have a backup. Plus get and intercooler. Plus a pyrometer, larger turbo, and install the Euro W140 Exhaust Manifold I got 6 months ago that is sitting on the shelf.
Inbox is cleared by a good amount. There has been a ton more research and development both on the injection pump and the car.
Stay tuned for a lot more information and more real world results
I dont remember if i asked, but how much these 7.5mm elements can supply fuel?
(07-23-2010, 03:34 PM)jeemu I dont remember if i asked, but how much these 7.5mm elements can supply fuel?
Very true!
Increasing the fuelling can be thought of as increasing the length of stroke of the plunger...(It doesnt actually, the effective stroke is longer Before the Spill-Port is uncovered
As the cam nears the end of its effective stroke, the speed of plunger rise falls off sharply, so fuel delivered approaching and at this point in its travel will be at a rapidly dropping pressure and take much time (relatively) to complete.
--Effectively the last fuel would dribble in....
All the fuel delivered at this point will then do is add to high EGT's and black-smoke while not really giving the full benefit of it actually being there!
Then again, I think with 7.5mm we will run out of air/engine capabilities--even with a mega tuned 606/605 with the biggest darn turbo you could fit, before this point in the delivery curve....
Myna get pretty impressive results with the smaller, 7mm plunger, so I doubt we would ever get near the end of useful fuelling provided by a 7.5mm!
(07-24-2010, 05:30 AM)Alastair E Then again, I think with 7.5mm we will run out of air/engine capabilities--even with a mega tuned 606/605 with the biggest darn turbo you could fit, before this point in the delivery curve....
This thread should never leave the first page!
Hey Derv, I PMed you about two 603 Pumps I am getting soon hopefully. Both are described as "non-working" but I have no other info than that. I figure these may be good as Cores or for spare parts. I can send them to you if you'd like!
(05-12-2010, 10:20 AM)DervTuning The super pump lives! For further testing of the bench settings on the pump, it is highly desirable to fit the pump to an engine to get dynamic qualitative, and quantitative feedback. The goal is to have a perfectly setup pump, with optimal delivery and response characteristics. This ensures that once the customer gets the pump, it is simply a plug and play situation. All fun, and no problems!Dev
Therefore, I installed the super pump onto the engine in the 85 w123 that is running an authentic Garrett, basically full T4 turbo (compressor and turbine wheels, with a t3 inlet on the turbine housing), a 3" diameter downpipe, and water injection, for an evaluation of idle response, as well as other key parameters for performance. This is in the case that something needs attention, the pump can be fitted back to the bench for adjustments before being shipped out.
The results are in; the engine has never idled so well! Totally smooth, and driving at low speeds, the tip in response was excellent, with no issues with surging or other strange effects. Immediately, the effect of more fuel delivery, as well as faster delivery was observed, whilst driving a usual route.
Subsequently, merging onto the freeway, a wholly different beast was unleashed under the hood, with power like never before. Before I knew it, I was just over the speed I normally would drive at, just an ultra smooth flow of power coupled with fine sounds as the turbo responded. Very, very impressive! After a quick systems check, and a clear space in front of me, the transmission was placed into 3rd @ 65mph, yielding near 4K rpms and the throttle depressed; instantly, the boost shot up to ~30psi, as well as the EGTs which stabilized as the boost kicked in, and then wheelspin occurred! Incredible! This is not a small turbo either, but I've never seen it respond so well compared to other platforms I've tried the same turbo in (gas engines).
It should be noted that prior to the super pump install, with the stock MW adjusted to it's maximum, I was getting ~10 psi max.
I will be able to resume testing later in the day, and if everything goes as well as it has, the super pump will be shipped out straightaway!
(08-14-2010, 11:51 PM)walton chang how much more
power can I realize 20 to 30%?
http://superturbodiesel.com/std/dyno-res...l#pid16195
30psi? You have to be seeing valve float on the intake side right? That is an incredible dyno. What kind of EGTs are you running in these?
(08-16-2010, 12:30 PM)gsxr Since the other thread was closed (sigh), I'll repeat the question
(08-16-2010, 12:30 PM)gsxr Since the other thread was closed (sigh), I'll repeat the question:
Is the "water injection" injecting water, methanol, or a mixture...?
(08-16-2010, 12:34 PM)ForcedInduction Ditto on the "(sigh)", I've asked him not to lock my threads or delete on-topic posts in them.
(08-16-2010, 12:26 PM)winmutt http://superturbodiesel.com/std/dyno-res...l#pid16195
There is no valve float that I know of, just smooth power. The car would probably make more power, but without knowing the limits of things, we figured it was enough. The rev limiter was raised slightly again after the dyno session, and everything sounded fine up to just past 6k rpms .
I was not looking at the EGT on the dyno, but on the road with similar settings, the EGT would get up to about 725C. With the MW pump back on the engine, there is a lot more time to observe the behavior of the EGT gauge. As the boost climbs, the EGT rises to about 700C (slower injection compared to the 7.5mm elements), the water injection kicks in, and the EGT rapidly drops to about 600C and stays there. It seems to work well
(08-16-2010, 05:08 PM)ForcedInduction What has been done to the transmission in all of this?
When I first installed the Floyd M Pump, I had to change the shift points, by adjusting the bowden cable, so that the shifts would occur at higher rpms, otherwise, I was starting to get a bit of flaring. The next step would have been to adjust the modulator.
This is aside from the pump linkage and bowden cable adjustments necessary when switching between the MW and M pumps.
Wow. OK, for those of us who are a little slow (in more ways than one)... how does injecting plain tap water provide that kind of additional power? I had (wrongly) assumed you were injecting methanol which was adding extra fuel, to provide the power gain. I understand the water injection reducing EGT's, but I don't get where the ~20% power gain came from. Perhaps the pump adjustment also increased the fuel delivery...?
(08-17-2010, 09:54 AM)gsxr Wow. OK, for those of us who are a little slow (in more ways than one)... how does injecting plain tap water provide that kind of additional power? I had (wrongly) assumed you were injecting methanol which was adding extra fuel, to provide the power gain. I understand the water injection reducing EGT's, but I don't get where the ~20% power gain came from. Perhaps the pump adjustment also increased the fuel delivery...?
Yes, it is from a combination of water injection, fuel delivery, the increased rev limit, and more boost.
The rev limiter begins acting earlier than the actual final rev limit, and starts reducing fuel quantity progressively until you near the final rev limit, where it really shuts things down.
This is in contrast to, for example, a rev limiter on a gas engine.
However, with the increased rev limit, the engine's power output felt just like a turbo gas engine
Another question from the peanut gallery... you mentioned increased boost on the second dyno run. Was that the result of changing the wastegate setting to open at higher pressure, or was it a result of supplying more fuel via the increased governor/limiter adjustment? Maybe both?
The methanol must be counteracting the water, my EGTs don't drop even a tiny bit when its activated.
That was my experience as well with liquid injection on a 603... I used a methanol mix (uh, actually cheap blue washer fluid) and although I did observe a 7-10% power gain when shooting in enormous amounts of blue juice, the EGT's were absolutely unchanged. I think I tried the same with plain water and there was no power gain and no EGT change. I did observe reduced IAT's when the liquid injection was operational, but that was the only visible difference.
(08-17-2010, 02:33 PM)gsxr Another question from the peanut gallery... you mentioned increased boost on the second dyno run. Was that the result of changing the wastegate setting to open at higher pressure, or was it a result of supplying more fuel via the increased governor/limiter adjustment? Maybe both?
(08-17-2010, 06:10 PM)ForcedInduction The methanol must be counteracting the water, my EGTs don't drop even a tiny bit when its activated.
It is from both
Also, thanks for the additional compliments
(05-12-2010, 10:20 AM)DervTuning The super pump lives! For further testing of the bench settings on the pump, it is highly desirable to fit the pump to an engine to get dynamic qualitative, and quantitative feedback. The goal is to have a perfectly setup pump, with optimal delivery and response characteristics. This ensures that once the customer gets the pump, it is simply a plug and play situation. All fun, and no problems!David
Walton, PM on the way.
I lowered the set point that starts the water injection, with better results.
Here is a video that shows the interaction of the water injection and EGT gauge behavior:
http://www.youtube.com/watch?v=6XX_BfGD3kE
thats some great stuff there. I should be back from poland thrusday, will send a PM your way about my progress and what I need from you hahaha
(07-24-2010, 05:00 PM)TymbrymiYep. Here is couple cars fueling now. about 180-190mm3, but with 8mm pumps that gan give max 225mm3.(07-24-2010, 05:30 AM)Alastair E Then again, I think with 7.5mm we will run out of air/engine capabilities--even with a mega tuned 606/605 with the biggest darn turbo you could fit, before this point in the delivery curve....
I dunno about that! jeemu has 529HP out of his 605!!
Bump - Anyone heard anything from Derv or any kind of update?
