STD Tuning Engine 7,5 mm Element design for high performance engine
  • 5 Vote(s) - 4.8 Average
Pages (9): Previous 1 4 5 6 7 8 9 Next
dieselmeken
11-10-2012, 12:19 PM #251
GTG At dieselmeken workshop today 20121110
http://www.facebook.com/dieselmeken#!/me...341&type=1
Development goes on, this is phase 2, 7,5mm performance maxed out
OBS Element on cyl 5 was changed, bad quality.
One glad dieseltech.
One 7,5mm testpump, this one goes up in dyno soon. Result will be shown.
This post was last modified: 11-10-2012, 12:21 PM by dieselmeken.
dieselmeken
11-10-2012, 01:58 PM #252
I predict the engine cant take it!
EDH_Performance
11-10-2012, 03:35 PM #253
(11-10-2012, 01:58 PM)winmutt I predict the engine cant take it!
Hoho, it's my engineBig Grin
EDH_Performance
mantahead
11-10-2012, 03:36 PM #254
hi,
is that pump running on steroids?Big Grin
mantahead
hi,
EDH_Performance
11-11-2012, 12:37 PM #255
(11-10-2012, 03:36 PM)mantahead hi,
Yes, we filled it with some Norwegian steroids;D I will fit this pump one of the comming days!
EDH_Performance
Ksteen2
11-12-2012, 05:51 AM #256
This will be awesome EDH, But you need a bigger turbo Wink
Ksteen2
raidaru
11-12-2012, 12:33 PM #257
HX55 , propane injection, water/metanol injection for lower EGT, all internals changed, and you'll have a 1000 hp/1500nm dyno engine, as in the car......ther's no tranny who'd hold that Smile)) GL brah and waiting for the results these days Wink
raidaru
EDH_Performance
11-13-2012, 12:28 PM #258
A little testdrive before I changed to better pumpBig Grin This is with 225 tyres...
This post was last modified: 11-13-2012, 12:30 PM by EDH_Performance.
EDH_Performance
Ksteen2
11-15-2012, 09:05 AM #259
when are you giong to post a new film with new pump? Wink
Ksteen2
EDH_Performance
11-15-2012, 10:44 AM #260
(11-15-2012, 09:05 AM)Ksteen2 when are you giong to post a new film with new pump? Wink
My last exam is 3.des, so after that I will mount the intake and compressor! I will the dyno the car with 140cc, 180cc and maybe 210cc if the turbo can supply enough airBig Grin (I think it can handle 180cc, but not 210cc..)
After the dyno session, the air setup will be changed...Compressor will be removed and compound setup will be built;D
This post was last modified: 11-15-2012, 10:44 AM by EDH_Performance.
EDH_Performance
m2rkz
11-15-2012, 10:44 AM #261
I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
This post was last modified: 11-15-2012, 10:46 AM by m2rkz.
m2rkz
Any ideas?
EDH_Performance
11-15-2012, 11:02 AM #262
(11-15-2012, 10:44 AM)m2rkz I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
there is no such thing as "the motor gets to much fuel", you simply need more airBig Grin
And this sounds like a fuelfeed problem! Have you changed the fuel lines and mounted big feed pump?
EDH_Performance
Any ideas?
m2rkz
11-15-2012, 11:10 AM #263
(11-15-2012, 11:02 AM)EDH_Performance
Any ideas?
3500grm and there is enough air and then when more and more grm then the engine is like dieing. Logic is than if more grm then more air.
but yes. Fule line and feed pump is not installed.
m2rkz
Any ideas?
EDH_Performance
11-15-2012, 11:14 AM #264
Are you running stock feed pump? (The one that sits on the pump)
EDH_Performance
m2rkz
11-15-2012, 11:17 AM #265
If dieselmeken didn't do with this anythind then yes. Where I can get better feed pump?
m2rkz
EDH_Performance
11-15-2012, 11:22 AM #266
(11-15-2012, 11:17 AM)m2rkz If dieselmeken didn't do with this anythind then yes. Where I can get better feed pump?
I am very impressed that the stock fuelfeedpump made 194kw!!!!!!!!!!!!!!
You need big feedpump and atleast 10mm fuel lines ALL the way into the pump! Remove the stock fuel heater, and run the lines directly from feedpump to dieselpump...Maybe you need to uppgrade banjobolt on dieselpump for enough flow! Rememeber a good highflow dieselfilterWink
Holley makes a good feedpump or you can use the bosch 044 pump!
EDH_Performance
erling66
SuperDieselVan
294
11-15-2012, 11:24 AM #267
Any ideas?
Take some photos of your engine setup, then it is easier to give you some advise.
HuhCoolTongue
erling66
Any ideas?
HuhCoolTongue
m2rkz
11-15-2012, 12:09 PM #268
(11-15-2012, 11:22 AM)EDH_Performance
Do you have any pictures of installing bigger feed pump?
m2rkz
EDH_Performance
11-15-2012, 12:11 PM #269
(11-15-2012, 12:09 PM)m2rkz
No, i don`t haveSad But this is not hard to do, just mount one or two 044 pumps under the car (or where if fits the best) and buy some 10mm copper/pvc tubes and clamp them under the car from fuelpump and forwrd to the engineWink
EDH_Performance
m2rkz
11-15-2012, 12:12 PM #270
(11-15-2012, 11:24 AM)erling66
Any ideas?
www.facebook.com/photo.php?fbid=346084165488355&set=a.346083522155086.79823.283288528434586&type=1&theater
http://www.facebook.com/photo.php?fbid=3...=3&theater
m2rkz
Any ideas?
EDH_Performance
11-15-2012, 12:21 PM #271
impressive buildBig Grin How many cc is your pump giving?
EDH_Performance
m2rkz
11-15-2012, 12:21 PM #272
in winter we gonna add eaton m62 with electronic clutch too to get 1 bar pressure already from 2000grm. Do you think is it good idea?
m2rkz
EDH_Performance
11-15-2012, 12:26 PM #273
(11-15-2012, 12:21 PM)m2rkz in winter we gonna add eaton m62 with electronic clutch too to get 1 bar pressure already from 2000grm. Do you think is it good idea?
No, atleast a m90...Best would be m112!
EDH_Performance
m2rkz
11-15-2012, 12:32 PM #274
m62 is with electronic clutch and then if more than 2000grm it turns off...
m90 and m112 is without clutch and it's not good.
m62 witch clutch is quite cheap too and it is ok for 1 bar in 2000grm.
one more question.
But original feed pump is installed to dieselpump. And between them is gasket. Then I must remove the origanal feedpump or I just install one more fuelpump under the car?
(11-15-2012, 12:21 PM)EDH_Performance impressive buildBig Grin How many cc is your pump giving?
I don't know. I order it in February. I think I will send the pump back and then dieselmeken test it again.
This post was last modified: 11-15-2012, 12:56 PM by m2rkz.
m2rkz
one more question.
Savitas
11-15-2012, 02:29 PM #275
(11-15-2012, 12:32 PM)m2rkz m62 is with electronic clutch and then if more than 2000grm it turns off...
one more question.
What about IP timing? Have you tried to change it a few degrees?
Push like on my project facebook http://www.facebook.com/OMperform
Savitas
one more question.
m2rkz
11-15-2012, 02:54 PM #276
(11-15-2012, 02:29 PM)Savitas
one more question.
yes. but still same results.
m2rkz
one more question.
dieselmeken
11-15-2012, 03:27 PM #277
Its à 140cc pump. Its good for 400+ hp
dieselmeken
EDH_Performance
11-15-2012, 04:13 PM #278
I have tried a 140cc pump form dieselmeken, with just stock feed pump! The car behaved just as you descibe it! Pulling fine at low rpm, but not at highBig Grin Uppgrade feedpump and your problem is solved;p
EDH_Performance
m2rkz
11-15-2012, 04:16 PM #279
(11-15-2012, 04:13 PM)EDH_Performance I have tried a 140cc pump form dieselmeken, with just stock feed pump! The car behaved just as you descibe it! Pulling fine at low rpm, but not at highBig Grin Uppgrade feedpump and your problem is solved;p
I think I want 180cc pump. I hope diselmeken will do me a good price.
m2rkz
jeemu
457
11-15-2012, 04:28 PM #280
Max cc isint all about it Wink
This post was last modified: 11-15-2012, 04:29 PM by jeemu.
jeemu
m2rkz
11-15-2012, 04:59 PM #281
(11-15-2012, 04:28 PM)jeemu Max cc isint all about it Wink
You think 140cc is good enough for exampe 550hp with this settings? If I will put better feed pump and 10mm hoses and better fuelfilter?
m2rkz
erling66
SuperDieselVan
294
11-16-2012, 04:17 AM #282
Hi m2rkz.
Nice engineSmile But I am not so sure about your intake manifoldHuh ; maybe there is some horsepower to gain from making a manifold similar to what Jeemu has?
HuhCoolTongue
erling66
Hi m2rkz.
HuhCoolTongue
m2rkz
11-16-2012, 07:00 AM #283
(11-16-2012, 04:17 AM)erling66 Hi m2rkz.
any pictures of that intake?
And why is original om603 diesel filter bad?
m2rkz
EDH_Performance
11-16-2012, 08:30 AM #284
(11-16-2012, 07:00 AM)m2rkz
stock filter housing has small banjo and connectings, all has to be atleast 10mm.
EDH_Performance
erling66
SuperDieselVan
294
11-16-2012, 11:38 AM #285
You will find some photos here: http://www.youtube.com/watch?v=j8E6bGyj_hI
The 603 filter is designed for 150hp. I guess your plan is to have a few more?Wink
HuhCoolTongue
erling66
HuhCoolTongue
jeemu
457
11-16-2012, 01:45 PM #286
(11-15-2012, 04:59 PM)m2rkz
7mm 140cc cant get same power than 8mm 140cc
jeemu
dieselmeken
11-16-2012, 02:34 PM #287
(11-16-2012, 01:45 PM)jeemu
Its 7,5mm 140cc.
dieselmeken
Its 7,5mm 140cc.
jeemu
457
11-16-2012, 03:30 PM #288
(11-16-2012, 02:34 PM)dieselmeken
(11-15-2012, 04:59 PM)m2rkz You think 140cc is good enough for exampe 550hp with this settings? If I will put better feed pump and 10mm hoses and better fuelfilter?
Its 7,5mm 140cc.
7,5mm 140cc cant get same power than 8mm 140cc Wink
jeemu
Its 7,5mm 140cc.
dieselmeken
11-16-2012, 04:07 PM #289
(11-16-2012, 03:30 PM)jeemu
(11-16-2012, 01:45 PM)jeemu 7mm 140cc cant get same power than 8mm 140cc
Its 7,5mm 140cc.
That depends on The duration of The element. Do you know how many degrees it takes for The 8 to inject 140cc?
dieselmeken
Its 7,5mm 140cc.
Turbo
11-16-2012, 04:10 PM #290
seams like now Dieselmeken is in the amount like Mynä, but still no 8mm
Turbo
jeemu
457
11-16-2012, 04:42 PM #291
Pump bench you can result you want.
Only that matters is how much and how fast, Dieselmerken just dont want to understand my guestion, asked many times Smile case closed. myy opinioin is at ewerybody can do what they want.
jeemu
Turbo
11-16-2012, 04:56 PM #292
That is another way of saying it
(11-16-2012, 04:42 PM)jeemu Pump bench you can result you want.
Turbo
EDH_Performance
11-17-2012, 07:17 AM #293
Hp is hp, but think about the driveability? 7.5mm in a dialy driver is ok, but very sensetive in the trottle! dont't wanna think about 8 or 8.5mm.... I am now speaking if you drive a Manual transmission, NOT automatic!!!
EDH_Performance
m2rkz
11-17-2012, 08:47 AM #294
(11-17-2012, 07:17 AM)EDH_Performance Hp is hp, but think about the driveability? 7.5mm in a dialy driver is ok, but very sensetive in the trottle! dont't wanna think about 8 or 8.5mm.... I am now speaking if you drive a Manual transmission, NOT automatic!!!
I drive with automatic transmission. gearbox is from 1999 w210 e55 amg. And the car is 1986 c126 sec 500.
EDH_Performance : I have the same question for you that I asked from dieselmeken. What do you think which pump is better for daily drive if I want 500 or maximum 600hp and wanna drive long trips with 2000grm too. For lower grm we gonna install m62 with electronic clutch. Which is better: 140cc pump or 180c pump with 7,5mm elements? I want your opinion.
m2rkz
EDH_Performance
11-17-2012, 09:14 AM #295
I would go for 180cc 7,5mm with outside alda! I have driven MANY long trips with my car, no problem at all! You could go 8mm, but the price is high! Gørans pumps is good quality!! I have personally been in his workshop and he showd us every step under the build...try to get the other pumpbuilders to do thatWink
EDH_Performance
Siekkinen
11-17-2012, 04:18 PM #296
Any ideas?
There is something wrong with it. I got same results from om603 with 80mm3, 1.5 bars (holset hx35) and of course a stock feedpump.
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
Any ideas?
w202 250 TDT
w201 2.6E
jeemu
457
11-17-2012, 05:12 PM #297
605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
My woman go daily store shoping Smile
jeemu
EDH_Performance
11-17-2012, 05:16 PM #298
(11-17-2012, 05:12 PM)jeemu 605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
Manual trans?
(11-17-2012, 04:18 PM)Siekkinen
Any ideas?
Thats a perfect example on that the stock feed pump can handle up to 80cc of fuel, even if the pump is setup for 140ccBig Grin
Manual trans?
This post was last modified: 11-17-2012, 05:18 PM by EDH_Performance.
EDH_Performance
Manual trans?
Any ideas?
Manual trans?
Siekkinen
11-17-2012, 07:07 PM #299
I have seen many +400 hp results with a stock feed pump. It depends on many things Big Grin but if you really need much power, you need to upgrade the feed pump to electric and fuel lines to 10mm.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
11-17-2012, 08:50 PM #300
(11-16-2012, 02:34 PM)dieselmeken That depends on The duration of The element. Do you know how many degrees it takes for The 8 to inject 140cc?
Meken has a point. If there is an ideal duration time and delivery amount is to be fixed at 140cc, then it stands to reason that a bigger element isn't necessarily better.
 49 Guest(s)
 49 Guest(s)
