7,5 mm Element design for high performance engine
(11-16-2012, 04:42 PM)jeemu Pump bench you can result you want.
Only that matters is how much and how fast, Dieselmerken just dont want to understand my guestion, asked many times case closed. myy opinioin is at ewerybody can do what they want.
(11-18-2012, 12:15 PM)erling66(11-17-2012, 05:12 PM)jeemu 605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
My woman go daily store shoping
Impressive woman especially with those tires this time of the year
now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.
Maybe 140cc 7,5mm pump is not good.
(11-22-2012, 01:18 PM)m2rkz now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.
(11-22-2012, 01:18 PM)m2rkz now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.hi,
(11-22-2012, 01:26 PM)EDH_Performance(11-22-2012, 01:18 PM)m2rkz now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.
what kind of exhaust do you have?
(11-22-2012, 03:14 PM)mantahead(11-22-2012, 01:18 PM)m2rkz now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.hi,
how many degrees spill timing have you got?
This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
What kind of pump did you install? does the fuelflow go trough the stock feedpump or directly to the injection pump?
You should burn 3rd gear easily with this pump
(11-22-2012, 03:36 PM)EDH_Performance This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
(11-22-2012, 07:39 PM)m2rkzAs I told you in mail, I do the pump again to check it up, or upgrade it to you to thge 180cc edition(11-22-2012, 07:34 PM)Mark_M Are you getting smoke but no more boost or is it clean?
at the beginning smoke and in the end clean....
(11-23-2012, 03:31 PM)dieselmeken(11-22-2012, 07:39 PM)m2rkzAs I told you in mail, I do the pump again to check it up, or upgrade it to you to thge 180cc edition(11-22-2012, 07:34 PM)Mark_M Are you getting smoke but no more boost or is it clean?
(11-23-2012, 08:37 PM)winmutt Silliest of questions, checked all the charged air joints for leaks?
(11-24-2012, 12:14 AM)m2rkz(11-23-2012, 08:37 PM)winmutt Silliest of questions, checked all the charged air joints for leaks?
no leaks at all. checked many times.
But is this 215 litres diesel after filter and before pump enough?
It is enough for petrol engine. But for diesel?
EDH_Performance - please do a test for me. Calculate how much diesel per hour you will get after the filter and before injection pump with battery. And before filter. For example: put your feed pump to work for 20 seconds and lead diesel to resrvior and then calculate the amont for one hour. I got 215 litres per hour before injecton pump and 240 litres per hour before filter.
I have 8mm hoses and just new big banjos for filter. 8mm is good enough for 600hp with petrol engine. Tested.
I think at that -044 not flow enough. Why use that anyway?
No need 3bar trancfer pressure, 1bar is enough. Tested.
Try OEM lift pump.
(11-24-2012, 01:09 PM)jeemu I think at that -044 not flow enough. Why use that anyway?In testbench 1 bar is not enough with My elements. Pump starts to reduce fuel at 2600 rpm and up. When i put 3 bar in it supply fuel. Tested. But probably My elements is not so good as mynäs and herlevi
Try OEM lift pump.
Try OEM lift pump.
(11-22-2012, 07:10 PM)m2rkzDo you have any videos from when you are driving?(11-22-2012, 03:36 PM)EDH_Performance This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
yes I can burn 3rd gear but that's not the point. And ofcourse fuelflow go directly to the injection pump. We installed Bosch 044 and pressure regulator to 3 bar. And like I said we tested the fuelflow after the filter and directly before the diesel pump and it was very good. To 3500 or 4000 everything is ok but later the boost pressure will be the same or drop down little bit. Only problem can be the 140cc pump. Something is very bad there.
(11-24-2012, 01:19 PM)dieselmekenMaybe there is some difference in pumps.(11-24-2012, 01:09 PM)jeemu I think at that -044 not flow enough. Why use that anyway?In testbench 1 bar is not enough with My elements. Pump starts to reduce fuel at 2600 rpm and up. When i put 3 bar in it supply fuel. Tested. But probably My elements is not so good as mynäs and herlevi
Try OEM lift pump.
Try OEM lift pump.
Try OEM lift pump.
(11-24-2012, 01:24 PM)erling66(11-22-2012, 07:10 PM)m2rkzDo you have any videos from when you are driving?(11-22-2012, 03:36 PM)EDH_Performance This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
Try OEM lift pump.
Try OEM lift pump.
Try OEM lift pump.
Has anyone ever tried to add a fuel accumulator after the lift pump? Its a piston pump so the pressure pulses and is less for some cylinders than others..
Small test of the new 210cc Dieselmeken prototype!!
Works really good, but 4th gear didn`t love me in this video...
The motor runs very good, and work perfect on the road, daily driving
(11-25-2012, 03:54 PM)EDH_Performance Small test of the new 210cc Dieselmeken prototype!!
Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easily I see now that i need new camshafts and bigger turbo and maybe some new slicks tyres
I have evil plans, so stay tuned
(11-26-2012, 12:16 PM)EDH_Performance Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easily I see now that i need new camshafts and bigger turbo and maybe some new slicks tyres
(11-26-2012, 12:41 PM)dieselmeken(11-26-2012, 12:16 PM)EDH_Performance Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easily I see now that i need new camshafts and bigger turbo and maybe some new slicks tyres
Bad pump, something is wrong, You should spin on 5:ft gear while your girfriend drive to the shopping mall, my misstake..sorry På Svenska kallar vi detta Ironi.
(11-26-2012, 12:56 PM)EDH_PerformanceIf you'r coming to Hamar soon, you can buy one of mine turbos, i have an BW KKK 31 and a BW KKK 30 and a Holsett HX60(11-26-2012, 12:41 PM)dieselmeken(11-26-2012, 12:16 PM)EDH_Performance Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easily I see now that i need new camshafts and bigger turbo and maybe some new slicks tyres
Hoho, with bigger turbo, 5th gear will also burn tyres Just you wait my friend
The whole engine setup is to be modified, exhaust, intake and engine parts
(11-27-2012, 03:11 AM)Ksteen2(11-26-2012, 12:56 PM)EDH_PerformanceIf you'r coming to Hamar soon, you can buy one of mine turbos, i have an BW KKK 31 and a BW KKK 30 and a Holsett HX60(11-26-2012, 12:41 PM)dieselmeken Bad pump, something is wrong, You should spin on 5:ft gear while your girfriend drive to the shopping mall, my misstake..sorry På Svenska kallar vi detta Ironi.
i think the HX60 will fit you perfekt
(11-27-2012, 03:45 PM)EDH_Performance Hahah, I just bought his HX60! Maybe now i can burn all 210cc
(11-27-2012, 05:39 PM)Siekkinen(11-27-2012, 03:45 PM)EDH_Performance Hahah, I just bought his HX60! Maybe now i can burn all 210cc
Or then you get problems with a cylinderhead the air just can't get through fast enough. hx52 pro or hx55 are enough at least for 800 horsepower with that engine. Proofed
You crazy mofo! I can't wait to see this when it's done!
I've been watching this build for a little while now and I'd be happy to be at even half your power! You've got some skills and the money you've spent on this must be a serious amount. What do you do for a living btw?
I currently have a 190d 2.5 na and I'm planning on putting in an om606 in the near future.
Were there any major issues you had with this conversion? Do you think the standard manifold and turbo is able to fit in a right hand drive car despite the steering box being in the way?
210cc pump was to much for this china turbo...
Listen to the strange sound everytime the turbo hits boost!
Minute after the compressor wheel came apart
I hope none of that ended up in your engine!
(11-29-2012, 11:21 AM)300SD81 I hope none of that ended up in your engine!
(11-27-2012, 06:07 PM)hooblah You crazy mofo! I can't wait to see this when it's done!
(11-29-2012, 01:27 PM)majesty78 Looks like Turbobanditen Turbocharger ?
(11-29-2012, 03:52 PM)Siekkinen(11-29-2012, 11:14 AM)EDH_Performance 210cc pump was to much for this china turbo...
How dear you use chinese turbos on these engines?
(11-29-2012, 04:23 PM)hansebanger77 Working Tacho would be nice ;-)Tacho works fine, the speedometer doesn`t I never drive fast you know, always 20km`h
(11-30-2012, 03:00 AM)Ksteen2 This showes that Dieselmekken's diesel pumps works greatMy 7,5mm pumps kills turbos, not good
to much fuel :p xD
to much fuel :p xD
(11-29-2012, 04:32 PM)EDH_Performance(11-29-2012, 04:23 PM)hansebanger77 Working Tacho would be nice ;-)Tacho works fine, the speedometer doesn`t I never drive fast you know, always 20km`h
(12-01-2012, 03:00 PM)hansebanger77(11-29-2012, 04:32 PM)EDH_Performance(11-29-2012, 04:23 PM)hansebanger77 Working Tacho would be nice ;-)Tacho works fine, the speedometer doesn`t I never drive fast you know, always 20km`h
Working speedometer would be nice :-)
Although it is no 7.5mm pump, I like to share my great experience with Göran from Dieselmeken:
He was so kind to make a short clip of rebuilding my Common Rail injectors:
Rebuild from 320CDI to AMG C30 spec.
Göran definitely knows his stuff :-)))
