STD Tuning Engine 7,5 mm Element design for high performance engine
  • 5 Vote(s) - 4.8 Average
Pages (9): Previous 1 5 6 7 8 9
ErikT
07-10-2013, 03:39 PM #401
Drove down to Göran yesterday to pick up my pump and also collect some others.
I had a great time, so thank you Göran!
Mine's for a G W461 with 617A. Looking forward to try it.
[Image: ndgl.jpg]
This post was last modified: 07-10-2013, 03:41 PM by ErikT.
ErikT
[Image: ndgl.jpg]
07-10-2013, 09:47 PM #402
TSA must have done some serious fondling LOL
Domino81
07-17-2013, 06:56 AM #403
Does anybody know at which turbo pressure (bar, psi) does the external ALDA valve open to deliver more fuel in dieselmeken's 140cc 7,5mm?
Domino81
dieselmeken
07-17-2013, 10:40 AM #404
(07-17-2013, 06:56 AM)Domino81 Does anybody know at which turbo pressure (bar, psi) does the external ALDA valve open to deliver more fuel in dieselmeken's 140cc 7,5mm?
Start at 0,3 and make max a b1- 1,5 bar
dieselmeken
yankneck696
395
07-18-2013, 08:12 AM #405
I need to get some paper towels....
Ed
yankneck696
Ed
Domino81
07-18-2013, 01:59 PM #406
Strangely my ALDA actuator starts working @ about 2 bar - but it wansn't tested under load.. just free neutral revs..
Will test and let you know the outcome, If the same thing happens under load as well, than I assume exchanging it for a different one shouldn't be a rocket science?
[/align]
Domino81
[/align]
maxypriest
07-18-2013, 05:59 PM #407
A basic question here... Apologies.
Does a '230cc' fuel pump move 230cc of fuel per cylinder per 1000 engine strokes?
Max
maxypriest
Max
EDH_Performance
07-19-2013, 04:02 AM #408
(07-18-2013, 05:59 PM)maxypriest A basic question here... Apologies.
Max
230cc pr 1000 element strokeWink
Max
This post was last modified: 07-19-2013, 04:11 AM by EDH_Performance.
EDH_Performance
Max
Max
HaavardPYA
07-19-2013, 10:13 AM #409
Pr cylinder or all 6 cylinders total?
HaavardPYA
Turbo
07-19-2013, 01:48 PM #410
Some body here know how fare up in rpm Dieselmekens "280cc" pump can deliver?
Turbo
dieselmeken
07-21-2013, 09:09 PM #411
(07-19-2013, 01:48 PM)Turbo Some body here know how fare up in rpm Dieselmekens "280cc" pump can deliver?
I know!
Tests in bench shows full fuel up to 6000 rpm so far, not ready yet
One 8mm 242cc 5cyl for OM605 did 7000rpm, that engine goes up in dyno around September-October
After vacation the 280 goes to pieces again, new set of elements vill go in it.
Moore to come, stay tuned.
dieselmeken
I know!
Turbo
07-22-2013, 02:58 AM #412
The Herlevi make 270cc fuel up to 6800rpm, if your 280CC pump can make full fuel up to 7000rpm it would be very interesting, please update us how it goes
(07-21-2013, 09:09 PM)dieselmeken
I know!
Turbo
I know!
maxypriest
07-23-2013, 08:36 AM #413
Goran – when you modify the pumps (8.0mm RS203) does the throttle lever on the pump move in a greater arc than compared with standard?
I ask as I have adapted the standard NA 606 mechanism for a turbo 606 intake, wondering if I need to make its range greater.
Regards,
Max
maxypriest
Regards,
Max
mantahead
07-23-2013, 12:34 PM #414
(07-23-2013, 08:36 AM)maxypriest Goran – when you modify the pumps (8.0mm RS203) does the throttle lever on the pump move in a greater arc than compared with standard?
Regards,
Max
hi,
yea you will need more travel, i would think.
This post was last modified: 07-23-2013, 12:36 PM by mantahead.
mantahead
Regards,
Max
hi,
HoleshotHolset
07-26-2013, 06:43 AM #415
(07-23-2013, 08:36 AM)maxypriest ...I have adapted the standard NA 606 mechanism for a turbo 606 intake, wondering if I need to make its range greater.
I did the same thing on my build...
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
jeemu
457
07-27-2013, 03:23 PM #416
(07-22-2013, 02:58 AM)Turbo The Herlevi make 270cc fuel up to 6800rpm, if your 280CC pump can make full fuel up to 7000rpm it would be very interesting, please update us how it goes
I know!
Injection pump it self is not the whole thing.
This post was last modified: 07-27-2013, 03:24 PM by jeemu.
jeemu
I know!
EDH_Performance
07-28-2013, 08:20 AM #417
(07-27-2013, 03:23 PM)jeemu Injection pump it self is not the whole thing.
Soo true! You must burn it aswellBig Grin
EDH_Performance
dieselmeken
09-06-2013, 07:17 AM #418
New serie 7,5mm to the left & 8,0mm to the right. Arrived today, quality looks very good, quality test up next.
I come back with som results later on.
dieselmeken
hooblah
09-06-2013, 10:39 AM #419
Oh new series? What are the differences compared to the last series?
When will they likely be ready?
hooblah
EDH_Performance
09-06-2013, 01:26 PM #420
Looks very good, is this from the new suplyer you was telling me about?
Only one week left, and this badass of a pump wil be testedBig Grin
EDH_Performance
300SD_KY
super turbo diesel
121
01-21-2014, 05:41 PM #421
need a Goran super-pump for my 1979 300SD.
300SD_KY
F.R.A.S
01-23-2014, 09:33 AM #422
Dieselmeken is really the go to guy when it comes to driveable pumps. We have one 8mm 242cc and one 8mm 180cc on the dyno before summer. Both curtesy of Göran!
F.R.A.S
baldur
Fast
509
02-03-2014, 09:19 AM #423
Anyone care to elaborate what the flow figure quoted means? When someone says a 242cc pump, obviously it's not 242cc of fuel per injection event, but what is it?
Baldur Gislason
baldur
Baldur Gislason
EDH_Performance
02-03-2014, 12:43 PM #424
242cc means it is flowing 242cc after 1000 element stroke.
EDH_Performance
dieselmeken
04-28-2014, 11:10 AM #425
The 8 mm was OK in design and have worked OK in Engines, November 2013 a new element started to be designed, Now its ready and tested, 250cc of fuel, very good result.
Also a new improved 7,5mm 140cc is in da house, to be tested soon.
These elements can soon be purchased from me, How about that!
http://www.youtube.com/watch?v=vJM2ASZri...e=youtu.be
dieselmeken
Turbo
04-28-2014, 02:48 PM #426
how high in rpm can it withhold that delivering?
(04-28-2014, 11:10 AM)dieselmeken The 8 mm was OK in design and have worked OK in Engines, November 2013 a new element started to be designed, Now its ready and tested, 250cc of fuel, very good result.
Turbo
dieselmeken
05-03-2014, 06:49 AM #427
(04-28-2014, 02:48 PM)Turbo how high in rpm can it withhold that delivering?
First tryout in testbench was 220cc @2,5bar inlet pressure 2800rpm (5600 Engine rpm), 1500rpm pump did 250cc, its a improvment anyway.
dieselmeken
dieselmeken
06-26-2014, 02:56 PM #428
http://youtu.be/83oaTB98VkA
Now I have reached the end,i dont Think the M-pump can do much Moore than this. Stroked camshaft,1mm higher lift, 17mm rollers, 8 mm element, cut deliveryvalves. almost 300cc with 210bar testinjectors, This is Black Smoke Racings pump for their OM606DI Project.
dieselmeken
Turbo
06-26-2014, 04:39 PM #429
so High up in rpm can it hold that delivery?
and what is the target price
(06-26-2014, 02:56 PM)dieselmeken http://youtu.be/83oaTB98VkA
Turbo
06-26-2014, 05:00 PM #430
So whats next?
adapt a 12mm P7100 to a om606? Big Grin
So whats next?
Gearbound
In need of a OM606.96x
172
06-26-2014, 05:08 PM #431
adapt the 12mm p7100 to my ALH TDI jetta as well Smile
Gearbound
dieselmeken
06-27-2014, 01:58 AM #432
(06-26-2014, 05:00 PM)MFSuper90 So whats next?
Yes. Thats the Winter Project.
After that I go for the commonrail conversion.
dieselmeken
06-27-2014, 03:19 AM #433
Are there any different requirements for injection pump for DI over IDI?
Will be interessting to see how the SuperStroker works with stroked DI engine Smile
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
dieselmeken
06-27-2014, 03:42 AM #434
(06-27-2014, 03:19 AM)DiseaselWeasel Are there any different requirements for injection pump for DI over IDI?
You need a quicker injection time in DI Engine, Distributor pumps type Bosch VE is quicker, but cant deliver this amount of fuel I Think. It will work, question is how much Power they will get, I doubt that it will give Moore Power than the IDI Engine, but I have done what i could whit this m-pump.
dieselmeken
06-27-2014, 04:37 AM #435
Thank you! So that's why Mercedes used VE pump on DI OM602 (290TD).
If it solves overheating problems and prevents pistons from melting, I think they are a huge step forwards in terms of reliability Smile
DiseaselWeasel
Spoolin
09-08-2016, 12:11 PM #436
I'm a little late to the party but this is a terrific thread with great information and results. Thanks for sharing so much.
Spoolin
 65 Guest(s)
 65 Guest(s)
